Sponsored by BimmerWorld
Old 07-26-2014, 01:29 PM   #1
CoryAshton
My Ride: 2003 325i turbo
Rear squeak speeds up with speed of car
I have a squeak that appears to be coming from the back right tire. I've already replaced the wheel bearing.The noise tends to lighten up whenever the clutch is in or in neutral. When coming to a stop it becomes a longer squeak. It has to be something rotation because as I'm coming to a stop it goes in and out and you can hear it squeaking at a certain point.. It's getting very frustrating.
CoryAshton is offline   Reply With Quote
Old 07-26-2014, 01:59 PM   #2
Dave1027
My Ride: '06 IR zhp coupe
Brakes? Caliper? I would trying jack up the rear and spin the wheel by hand to try to find the source of the noise.
Old 07-28-2014, 09:30 AM   #3
TheE46
My Ride: E46 M3
Wouldve guessed bearing but seeing you've already replaced it I would jack up the car and pull the wheel and see if maybe theres something going on in there. I had a weird noise one time in my car and pulled the wheel off to find a Whataburger wrapper stuck in some panels that was flapping on my wheels.
E46 M3 - AA Full Exhaust|KW Coilovers|aFe Intake
E90 335i - JB4|DCI
E46 Parts
TheE46 is offline   Reply With Quote
Old 07-31-2014, 10:32 AM   #4
CoryAshton
Thanks for the input, come to find out I used a national bearing from advanced and it went bad already. Replacing it today and hopefully it solves the issue!
Old 08-04-2014, 10:06 AM   #5
TheE46
My Ride: E46 M3
For the bearings I would stick with OEM definitely.
E90 335i - JB4|DCI
E46 Parts
