Old 07-30-2014, 05:46 AM   #1
Oskarotten
My Ride: 328ci
Engine light e46 328ci
Hi!
I have a problem with The yellow engine light on My e46
The car runs great when cold and if you drive it carefully.
The problem often comes up when I drive it hard or under load just after a a Cruise(cruisecontroll at 70mph then slow down and accelerate after the exit)
I have checked The codes with inpa and gets:
Misfire cyl 2
Avtivate grid controlled cooling
Any ideas?
Sorry for my bad english/ a swedish e46fantic
Oskarotten is offline   Reply With Quote
Old 07-31-2014, 12:31 PM   #2
BartenderPlease
My Ride: '03 540i/6 M-Sport
Thermostat housing needs replacing
Misfire could be from a bad coil pack/boot or spark plug. You aren't getting lean codes so I would start there.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 08-15-2014, 07:05 AM   #3
Loupland
My Ride: BMW 3.18i
That's definatly a bad coil... It's gonna break down completly at some point and you will notice it.
Your engine will run out of balance and it will shake. You will also loose engine power.
Do you also notice less RPM when in idle? Cause I had to replace a coil 3 times now and I had the exact symptoms as you have. I also noticed that the RPM dropped. Like, when the RPM's stay consistant the hole time, the coils are all good. But if you see your RPM change a little... sometimes a little more and then a little less, in idle, it means 1 coil is unstable.
A coil is like 45 euro. Just buy a new one and replace it in cilinder 2. Problem solved.
Loupland is offline   Reply With Quote
