3.07 to 3.46 Dif swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-07-2014, 10:07 AM   #1
hatetolovee46
My Ride: 02 325xi
I searched and found some diy's but not an answer to this question don't hate me plz! I have a 5spd 323i in gd condition other than the famous rear end clunk, my friends friend with a auto 323i's in terribad condition(clear coat failure, rips in seat ect) tranny died and is scraping the car, I swooped in and got it for close to free
Now since I have the rear end thud anyway and my 323i is in good condition otherwise I want to swap the 3.46 dif into it and replace all differentail bushings. Since it's possible the rear end clunk is also the subframe bushings I'm going to pull the subframe and do those as well, and since I'm pulling both of those and the subframe mounts have never been reinforced i'm going throw in the rear subframe mount reinforcement kit(already ordered for 130)
Little late in the game to be doing this with 170k on the car but idc I just want the thud gone
My question is thus, all DIY's and the hane's manual ofc say to mark the drive shaft to the input dif flange so you line it up right after and it is balanced, If i'm swapping the dif should i just cross my fingers it will be balanced after or go back and rotate it if there is a vibration, or can any shop balance it and if yea what's the usual charge for this?
Also how will this effect the cars electronics if at all? Won't throw a incorrect gear ratio code or anything will it assume all these sensors are upstream of the dif? Assume all electronics will be indifferent to the change yes?
hatetolovee46 is offline   Reply With Quote
Old 08-12-2014, 05:33 PM   #2
JasonSmithed
My Ride: 00 323i
I can't remember but it seemed as though the splines are on the guibo side. The rear diff just bolts on the end of the driveshaft. My clunk ended up being the flex disc/guibo. This took me maybe 4 hours to do. Good luck.
JasonSmithed is offline   Reply With Quote
Old 08-12-2014, 05:37 PM   #3
JasonSmithed
My Ride: 00 323i
Four hours for the whole swap. I marked the shaft in its relation to the guibo and tranny with white out.
Old 08-12-2014, 05:41 PM   #4
JasonSmithed
My Ride: 00 323i
Old 08-13-2014, 10:58 AM   #5
Bino5150
My Ride: 99 323i
That rear end thud is more than likely the subframe ripped loose from the car, rather than the bushings going bad. You might want to check... This is a known issue, and there's a little more to it that swapping parts. Other than curing the "thud", what do you hope to accomplish by swapping the differential?
Bino5150 is offline   Reply With Quote
Old 08-13-2014, 09:03 PM   #6
JasonSmithed
My Ride: 00 323i
There is a reinforcement kit. It's pricey for this car. Inspect the rtabs.
Old 08-14-2014, 11:43 AM   #7
Bino5150
My Ride: 99 323i
The reinforcement kit is actually not expensive. What is expensive is the actual repair, unless you can weld and have a lift.
