Sponsored by BAVSOUND
Old 08-08-2014, 09:44 PM   #1
2001Silver330CI
My Ride: 2001 BMW 330CI
Need new door mid-range speakers
My driver mid-range speaker started to crack and pop the last couple of days and I had to balance the sound all to the rear. What is the best value speaker to replace those mid-rangers in the doors of a coupe? Check out my signature for my current set up. TIA
2001 BMW 330 Ci
* Automatic
* Silver/Silver
* 20% Tint
* Pioneer DEH-X66BT head unit
* Polk Audio db651s speakers in rear deck
* Electric Fan Swap (CoolXpert)
* Clear Turn Signals/Markers
* New Behr radiator, BMW expansion tank, hoses (6/17/15)
2001Silver330CI is offline   Reply With Quote
Old 08-09-2014, 10:21 AM   #2
markusmarkus
My Ride: 2001 330Ci
Try a pair of Vifa full range speakers. I bought mine from www.madisound.com. They will require a bit of tape wrapped abound the speaker's perimeter so they fit snugly. They are wired backwards so solder the car's positive wire the speakers negative lead.
Old 08-09-2014, 03:11 PM   #3
2001Silver330CI
Thanks markusmarkus. Can you send me the link to the ones you got? I went to the site but only saw the tweeters.
2001 BMW 330 Ci
* Automatic
* Silver/Silver
* 20% Tint
Old 08-09-2014, 07:34 PM   #4
2001Silver330CI
Can I buy these brackets and speakers to replace my mid-range door speakers? Will it fit without modifications? What about the wiring harness?
Mounting Brackets
http://www.crutchfield.com/p_142SABW...s.html?tp=2824
Speakers
http://www.crutchfield.com/p_1131665...5S.html?tp=105
2001 BMW 330 Ci
* Automatic
* Silver/Silver
* 20% Tint
Old 08-09-2014, 08:39 PM   #5
Megalocnus
My Ride: 05 330i ZHP/MT
^No. Both these are way too large to replace your midrange speakers without major modifications to the door panels. Those may work as replacements for the large midbass speakers. The connector from the old speakers can be cut out and used for the new ones with some soldering. This is better than directly soldering the wires to the speakers as you will maintain ability to disconnect them easily in case you want to move the door panels away from the car.
The stock midrange front speakers come in threaded plastic housing. To maintain stock looks you need to find speakers that will fit in this housing or just order new ones from BMW. The stock midrange speakers aren't that bad BTW, the midbasses and the tweeters suck though.
Megalocnus is offline   Reply With Quote
Old 08-10-2014, 09:37 PM   #6
2001Silver330CI
Thanks Mega. I'll probably just purchase a used BMW door speaker and replace the current one.
http://www.ebay.com/itm/SPEAKER-MID-...1bf77a&vxp=mtr
2001 BMW 330 Ci
* Automatic
* Silver/Silver
* 20% Tint
Old 08-10-2014, 11:29 PM   #7
SoCaLe39
My Ride: 06 M5 & 03 325i
Why not something simple like a set of BSW mids?
SoCaLe39 is offline   Reply With Quote
Old 08-11-2014, 11:16 AM   #8
markusmarkus
My Ride: 2001 330Ci
http://www.madisoundspeakerstore.com...-driver-4-ohm/
Old 08-11-2014, 07:25 PM   #9
2001Silver330CI
mark....I thought the bottom speaker in the door was around 6"...not 2".
SoCaLe39....Looks like they are $159 for the front door midbases. I was trying to replace it for around $50.
http://www.bavsound.com/Stage-One/Buy-Now/
2001 BMW 330 Ci
* Automatic
* Silver/Silver
* 20% Tint
Old 08-12-2014, 08:36 AM   #10
markusmarkus
My Ride: 2001 330Ci
The larger speaker in the upper part of the door is considered to be the midrange speaker. The speaker in lower section of the door is the woofer. The OEM speaker is 6.25" in diameter but a 6.5" will fit.
Old 08-12-2014, 10:19 AM   #11
DonaldE
My Ride: 2002 330i
I personally love the JL C5's but you have to cut your door panels to mount like I did. But the midbass is soooo worth it
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
