Old 08-17-2014, 12:09 AM   #1
sieskei
My Ride: E46 325iA
M54B25 swap intake with B30
Hi guys,
I'm new here and I want to ask you a few things.
I want to replace the part of the m54b25's intake system with b30.
This modification include intake manifold + disa, throttle body, hoses and may be MAF and top of air box from b30.
1. If I swap the throttle body will it be controlled correctly?
2. I'm not sure I need a B30's MAF?
I guess the diameter is larger and can I use adapter (from larger to smaller hose) and stay with mine?
I also think that if I replace MAF sensor will need a remap / reflash.
What do you think about it?
10x in advance!
sieskei is offline   Reply With Quote
Old 08-17-2014, 01:36 PM   #2
HakenTT
My Ride: 323i with S54
Don't do it. Makes the engine run worse.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 08-17-2014, 02:46 PM   #3
sieskei
My Ride: E46 325iA
Why, can you explain?
Old 08-17-2014, 03:35 PM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
He is not a good source of info on this.
Contact "Iceman00" on this, he probably has the most & best info.
EDIT: Also contact "jared_wiesner", he did this on his 328.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
