Old 08-17-2014, 12:06 PM   #1
clipper88
Throttle response
Hi all, I have recently purchased a 330 CI, the throttle response is a bit sluggish for my liking.
Could anyone advise how I might go about sharpening it up?
Cheers
clipper88 is offline   Reply With Quote
Old 08-17-2014, 12:47 PM   #2
DieselFan
Start by resetting the adaptions.
Key in.
Turn electronics on with key one turn.
Accelerator pedal to the floor for 10 to 15s.
Key off.
Engine on.
Or do it via INPA of similar.
DieselFan is offline   Reply With Quote
Old 08-17-2014, 02:05 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Cheers
Shark Injector from forum sponsor Turner Motorsports.
http://www.turnermotorsport.com/p-26...-software.aspx
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Rob43 is online now   Reply With Quote
