Old 08-17-2014, 11:26 PM   #1
330_Fly
My Ride: '01 330i M-Package
Quick Assistance!! Could something be wrong?
My 01 330i Msport
w/ aFe CAI, TMS underdrive pulleys, Borla cat back, fully maintained through 200k miles, all fluid changed w/ redline, always royal purple full synth oil every 3k, and with only 90k miles on her...
AND I CANT DO A FLIPPIN BURNOUT ANYMORE!?!?!?
I'm not a chump... Lol, DCS was fully off (held for 8 sec). I have done plenty of burnouts, although it is very infrequent.
So I foolishly went to show off with my little bro in the car, rev'd to 4k rpm and dropped the clutch... Only to have the car go as if DCS was still activated I tried a few times after activating/deactivating DCS and still got the same response.
I would really appreciate any feedback on this issue for I fear that there may be a more serious (or less serious) problem that has arose. It's less about "burnouts" and more about the health of my car. Any ideas?
Sent from BimmerApp on 330_Fly's iPhone
330_Fly is offline   Reply With Quote
Old 08-18-2014, 11:04 PM   #2
rocky46
My Ride: 2003 330i
Hold dsc untill yellow brake light comes on
rocky46 is offline   Reply With Quote
Old 08-18-2014, 11:04 PM   #3
rocky46
My Ride: 2003 330i
Drop clutch at 6k rpm
Old 08-19-2014, 12:11 AM   #4
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Fry up some bacon in a large frying pan, save grease.
Enjoy bacon.
Later, smear bacon grease on tires. Enjoy burnout !!!
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-19-2014, 12:25 AM   #5
330_Fly
I'm serious guys, something isn't normal and I just want to know if anyone has heard of this or experienced it.
I can't figure out why I could before, but all of a sudden I can't... I've been researching for hours and I am assuming that it could have to do with the cdv.
Old 08-19-2014, 12:25 AM   #6
330_Fly
Enjoy bacon.
Good luck,
Rob43
Rob, I've read a lot of your stuff and you appear incredibly knowledgable. I'm not incompetent so please don't make that assumption. I took your advice, btw, about ground control coils. After doing extensive research and reading many reviews I decided to purchase. So, in all seriousness, could you help me at all?
Old 08-19-2014, 12:32 AM   #7
Rob43
Rob43's Avatar
Of course I'm just kidding around.....
First, I'm not sure if you have 200K or 90K on your Bimmer ?
Next, assuming that you are doing everything thing right, it sounds like the early stages of a clutch problem. How old is the (OE ?) clutch ?
Rob43
Old 08-19-2014, 12:39 AM   #8
rocky46
My Ride: 2003 330i
Either cdv or clutch. I tried launching with a bad clutch and I couldnt untill I putva new one
Do you still have your cdv?
Old 08-19-2014, 02:38 AM   #9
330_Fly
I have 90k miles on her with the cdv still installed. The oe clutch has 90k, it feels like it engages nearly perfect though.
Old 08-19-2014, 02:38 PM   #10
Rob43
Rob43's Avatar
Remove the CDV the next time you plan a day to do things to your Bimmer.
Adjust your tire pressure between 38 to 40 psi.
Slightly unrelated, change these parts if you haven't:
1) Fuel filter
2) NGK BKR7EIX
3) 2 Cans of BG 44K fuel injector cleaner
4) Oil change after you're done with the BG
Good luck,
Rob43
Old 08-19-2014, 10:04 PM   #11
330_Fly
1) Fuel filter
2) NGK BKR7EIX
Good luck,
Rob43
Thanks a lot for your advice! I'll let you know how it works.
