Old 08-21-2014, 11:19 PM   #1
PhEnX
My Ride: 01 330CI
Standalone tuning?
Is there software for the E46 that can be purchased that will allow you to tune the DME? Not wanting to buy a canned tune or spend $3000 on an AEM Infinity.. There must be another way?
PhEnX is offline   Reply With Quote
Old 08-22-2014, 03:11 AM   #2
daniel_f.
My Ride: 330iC
what would you like to tune? ignition? fuel? what measuring parts do you have for that purpouse?
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-22-2014, 02:25 PM   #3
B18c1turboedek
My Ride: 2002 330ci
I'm looking at trying the infinity 6. It's capable of doing the ignition and fuel.
2001 BMW 330ci Daily driver
2003 BMW M3 building for boost winter project
B18c1turboedek is offline   Reply With Quote
Old 08-24-2014, 01:04 AM   #4
PhEnX
My Ride: 01 330CI
Wanting to tune ignition and fuel have wideband dyno etc...
Old 08-25-2014, 12:28 AM   #5
HakenTT
My Ride: 323i with S54
There is no stand alone ECU available for these cars. You won't be able to get any more horsepower out of these engines anyway in naturally aspirated state.
HakenTT is offline   Reply With Quote
Old 08-25-2014, 12:51 PM   #6
JDUTHIE
My Ride: 2003 325xi
Vems, vipec, motec. Ms3.
JDUTHIE is offline   Reply With Quote
Old 08-25-2014, 07:14 PM   #7
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Once again, piss poor Bad Information.....
Hell, my Shark Injector made over 6 WHP on the dyno. On a E46 328 the Shark will make over 10 WHP.
Yep.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-25-2014, 07:48 PM   #8
HakenTT
Rob43
Not true. Even if it was. 6 WHP is nothing and would not justify investing $5000 in stand alone system. I can make 6 WHP on any car with running much thinner oil like 0-20w. Once again you with your childish nonsense
Old 08-25-2014, 09:14 PM   #9
Rob43
Rob43's Avatar
I certainly didn't have to do any of the nonsense you're talking about to gain my 6.5 WHP & greatly increased drive-ability. My Bimmer feels completely better on my Shark Injector, and it only cost me $300 at the time.
Thin oil.....LOL
Good luck,
Rob43
Old 08-26-2014, 09:11 PM   #10
jared_wiesner
My Ride: 1999 328i (M54b30)
I am never quite certain whether Haken spreads so much disinformation and abrasiveness to incite fights or whether he really is as misinformed as he has demonstrated. One way or another I am amazed he has not found himself banned.
A tune is entirely useful n/a or otherwise as has been demonstrated time and again.
jared_wiesner is offline   Reply With Quote
Old 08-27-2014, 12:22 AM   #11
daniel_f.
My Ride: 330iC
actually i dont understand why hes so misleading in the last times. if you take some time and have a look at older threads, one can find that he was a very interested and helpful person.
i really wonder what can happen to a person to become such a grumpy cat
Nevertheless, if i understand OP correctly, hes searching for tuning software instead of changing his ecu to proefi or similar.
there are at least three different possibilities:
- http://www.bmweditor.com/Home/Product
- if you are familiar with russian language: http://www.autodealer.ru/autoportal/equipment/item/248
- help us progressing: http://forum.e46fanatics.com/showthread.php?t=1044719
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-27-2014, 01:35 AM   #12
Rob43
Rob43's Avatar
Question, Do we know of Anyone who has bought and Successfully used this tuning software for MS43 ?
Rob43
Old 08-27-2014, 01:50 AM   #13
daniel_f.
My Ride: 330iC
well, it seems to be a "copy" of Chiptuning Pro, it even comes of the same region.
its actually just a damos file with translations for "the everyone" and a nice graphic interface. nothing which cant be done if a few others would work on MS43, too.
We even have a usefull tuner pro xdf file... it has just to be ordered and reduced to the basic things like ignition, fuel etc.
what im really missing is the enthusiasm the mss54 guys have had. they were so few, but they have done it almost completely.
sadly i just have my daily driver which i cant test that much i would like, so we would made so much progress if some others would chime in and help trying (practical) how things are arranged
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-27-2014, 02:04 AM   #14
HakenTT
Tune is horrible for these engines, safety margin is erased to gain very small peak horsepower of 6hp.
Ok so I answered the OP's question and not I am a bad guy? I told him there is none and now you give some links to some useless stuff. Quit spreading disinformation.
Old 08-27-2014, 05:18 AM   #15
SoloII///M
My Ride: Many
A standalone won't do much in terms of power unless the rest of the engine has some upgrades. I'm pretty confident that a good tuner (Randy Mueller for example) with access to a GT1 could make the same powerband as Peter and I made with the MS3 - it would just be a lot more expensive getting there and there are some other advantages to the MS3 that made it the right choice for me.
There is nothing particularly magical about standalone engine management. In many cases they use most or all of the stock BMW sensors and are controlling the stock BMW actuators (such as for the VANOS). The stock DME, when tuned correctly, can control all of those I/O to the same ranges as a standalone, so logically why would it make more or less power? The stock computer is fast. This isn't the 80's with dog-slow computers that can't adjust things finely enough or fast enough.
The reason we went to the Megasquirt is because there are very few people who know the DME well enough to tune it correctly, and they charge a pretty penny to do it. The MS3 is much easier to work with and gives you some options that a stock system doesn't - like a flex fuel sensor if you want to run ethanol, the ability to delete the MAF sensor, the ability to run a cable throttle body, etc.
I disagree with the statement that "tune is horrible for these engines, safety margin is erased..." We just haven't seen it to be true. In naturally aspirated trim, these engines are really resistant to pinging. They don't heat the fuel much (i.e. unlike a Miata) and they're not sensitive to too much ignition advance - we've never experienced preignition on my M54. They're insensitive to fuel mixture - we've played with this a lot and found that from "too lean" to "too rich" doesn't change power very much at all. And we've done all sorts of wacky things with the VANOS trying to find the sweet spot and not run across any problems.
In summary, are there standalones available for these engines? Yes.
Do they make more power than a professionally, custom-tuned DME? Not really.
Do they have other advantages over a stock DME? Definitely yes!
Does tuning an otherwise mostly-stock engine eliminate any safety margin? Not at all.
Hope this helps.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 08-27-2014, 06:19 AM   #16
jared_wiesner
Very well put solo.
As a side note, I am very curious about that bmw editor software.
Old 08-28-2014, 09:51 AM   #17
smooth1
My Ride: BMW FTW
I always go back and forth on this platform... whether there's real interest or if it should be left to run its course as TunerPro freeware.
smooth1 is offline   Reply With Quote
Old 08-28-2014, 10:50 AM   #18
jared_wiesner
I think there is enough interest that you could make a decent amount of money off of it smooth.
Old 08-28-2014, 11:25 PM   #19
smooth1
My Ride: BMW FTW
I think it'd be a fun project. Editing, flashing, and logging all in one. It doesn't need to be expensive to be good.
Old 08-28-2014, 11:55 PM   #20
daniel_f.
My Ride: 330iC
You know what i think of that idea
Would be awesome if it could handle an wideband/egt input and overlay that to the logging.
Siemens MS42 wiki!
Siemens MS43 wiki!
