Old 08-22-2014, 07:59 PM   #1
Andrew99328i
My Ride: 328i 99
What to do about rust in the cylinder.
I have my cylinder head at the shop and left my block covered with saran wrap wanted to know what you do if the block got rained on once and water was on the top of the block so the is a small rust build up? And i just clea ed off the HG MATERIAL from the deck and did not coat the cylinder walls with white grease. Ideas comments qustions?
Andrew99328i is offline   Reply With Quote
