Old 08-23-2014, 02:18 AM   #1
rocky46
My Ride: 2003 330i
Shark injector
Who here recommends the shark injector for what it does? I have the ms43 headers 3in exhaust afe intake
rocky46 is offline   Reply With Quote
Old 08-23-2014, 07:31 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I do.
Search Shark / Shark Injector.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-23-2014, 02:52 PM   #3
fth001
My Ride: 325i, e36m3, s13
Me too.
fth001 is offline   Reply With Quote
Old 09-24-2014, 01:57 PM   #4
DonaldE
My Ride: 2002 330i
Does the Shark clear the headers CEL?
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 09-24-2014, 02:07 PM   #5
Rob43
Rob43's Avatar
Not in any way.
The very high tech method I use to perform that function (this technique took years to develop) is to cut a piece of black electrical tape about 1" long & place it over said (CEL) light. Thus no more CEL light. I scan my Bimmer about once a month to see if I've thrown any codes.
Good luck,
Rob43
Old 09-24-2014, 02:17 PM   #6
rocky46
My Ride: 2003 330i
Same here
Old 09-24-2014, 02:18 PM   #7
rocky46
My Ride: 2003 330i
I think im getting a little bit of ping though. Im in California and use 91 gas
Old 09-24-2014, 02:22 PM   #8
Rob43
Rob43's Avatar
^ Mix in one gallon of race gas, see if you "ping" goes away.
EDIT: Are you using the "Ant-Knock Software" version ?
Rob43
Old 09-24-2014, 03:18 PM   #9
daniel_f.
My Ride: 330iC
Get yourself the BMWLogger software and you can see if knock occurs. Itīll look like this:
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-24-2014, 03:21 PM   #10
rocky46
My Ride: 2003 330i
No i just bought the regular software. How can i get that software?
Old 09-24-2014, 03:41 PM   #11
Rob43
Rob43's Avatar
You'd need to call Turner Motorsports & talk with "Drew", ask him what it would cost. Make sure you explain that YOU are the original owner of the Shark & that you bought the wrong model by accident, you want the software for CA. This is referred to as the "Anti-Knock" software, Drew will know exactly what you need.
Rob43
