Old 08-17-2003, 03:54 AM   #1
tmckinl
My Ride: Jet Black 1999 328i
Send a message via ICQ to tmckinl
Question shift indicator problem on auto trans
The indicator next to the automatic trans shifter on my 328i has started to malfunction. It dosn't indicate the correct gear. If I shift into park and then carefully shift back to gear it sometimes corrects itself, but only temporarily. Does anyone have any idea what's wrong and how I can fix it.
tmckinl is offline   Reply With Quote
Old 08-17-2003, 04:07 AM   #2
gmhl10
Resident CF Whore
My Ride: '05 A08 M3
Send a message via AIM to gmhl10 Send a message via MSN to gmhl10
Whoa.... never heard of that happenning.
I got an auto tranny problem on my 2002 325i where say when I go up to like around 5000 or 6000 rpm in 2nd gear and then switch to 3rd gear... instead it went down to 1st gear and I freaked the hell out because it went to total redline!
I pushed on brake and kept trying to shift up.
I know I didn't "ACCIDENTALLY" push down to gear 1 because it happened to me twice...
'05 Silbergrau M3 - mfg date: May '05
Modifications: WAY too much to list
gmhl10 is offline   Reply With Quote
Old 08-17-2003, 11:16 AM   #3
sfzBimmer2
My Ride: '05 Ducati Monster
I think someone else on this forum had a similar problem. It's a known problem, though, and your dealer should be able to fix it
sfzBimmer2 is offline   Reply With Quote
Old 08-17-2003, 11:17 AM   #4
Liscia
My Ride: 2002 BMW 330Ci
Could it just be a loose connection to the indicator light module?or gearshift lever position sensor.
Haven't had mine open but looks easy enough to pry off and
check connections underneath or you may want the dealer to
do this if you've got warranty left and if you're not confident of
doing it yourself. Good luck
Liscia is offline   Reply With Quote
Old 08-17-2003, 12:33 PM   #5
Trax
My Ride: 99' 323i Sedan
Send a message via ICQ to Trax Send a message via AIM to Trax Send a message via Yahoo to Trax
I had the same problem on my 1999 323i couple years ago. Took it to the dealer and they fixed it. Happened after my brother drove it...should tell you something
This sig has been viewed by fanatics since March 14, 2004
Trax is offline   Reply With Quote
Old 08-21-2003, 03:10 AM   #6
tmckinl
Thanks for the ideas. I think it's something mechanical with the indicator because of the sounds it makes when shifting. I think I'll get it to the dealer when I have a chance. It's really just a minor anoyance because the dashboard readout is still reading correctly.
Old 08-21-2003, 03:46 PM   #7
Cheburashka
My Ride: '99 328i
Seems to be a more common problem these days. I had same problem a year ago. Dealer fixed it by replacing something.
Improving with Age!
Cheburashka is offline   Reply With Quote
