Installing slab doors - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 02-06-2015, 05:07 PM   #1
5ynd1cat3
My Ride: pisses off liberals
Anyone ever done it? How much of a b!tch is it? CO wants rid of the ugly brown doors for white 6 panel. House was built in '55 so plaster walls and casing/frames are in good shape. I've done prehung before but never slab. Any pro tips?
5ynd1cat3 is offline   Reply With Quote
Old 02-06-2015, 11:51 PM   #2
invisible man
My Ride: invisible car
Do you know how to use a chisel properly? That's the biggest b!tch of it.
Giubo. G I U bo. Pronounced joo-boh. Don't allow yourself to sound ignorant.
invisible man is offline   Reply With Quote
Old 02-07-2015, 10:14 AM   #3
5ynd1cat3
Yeah I'm pretty handy with a chisel. My biggest issue is going from a plain Jane door to a 6 panel and getting the sizing right regarding the accents on the 6 panel. For the height/width I'm guessing I split the difference and trim off all sides to keep the panels centered? About how much material is available before I hit the hollow core?
Old 02-07-2015, 02:36 PM   #4
invisible man
There's no reason the new door should be a different size than the one you're replacing. All doors are standard sizes unless there is a reason for a non-standard size. If your house was built properly, you can take any door from any house on your street and it will fit the frame perfectly.
Old 02-07-2015, 02:39 PM   #5
invisible man
And exterior doors shouldn't be hollow unless it's a steel door. If you're using a 6-panel door that's hollow, that's an interior door.
Old 02-07-2015, 02:59 PM   #6
5ynd1cat3
You're right but like I stated house was built in 1955. I'd bet anything that nothing in this house is 100% plumb and/or level. 60 years of weather, settling, etc will affect things. Existing door is 78 7/8 x 29 5/8. I'm thinking an 80x30 door won't fit, hence my query.
And yes, it's interior door, not entry.
Old 02-19-2015, 09:06 AM   #7
Chris3Duke
My main recommendation is to get a decent door, not the $30 cardboard slabs they sell at the big box store. Expect to pay in the $100-$200 range.
The size they tell you is usually the rough opening size, not the actual door size (which will be in fine print). That's probably the discrepancy you're seeing.
If you still need to trim, most doors will tell you how much you can trim off each side. I use a table saw, but you could also use an electric hand planer. You're not generally taking enough off that it's worth it to remove material from more than one side.
Buy one pre-bored for a handle/knob.
After that, it's just morticing the hinge, installing the handle, and getting the reveal equal. Don't forget to allow for the height of the finished floor / carpet.
If your existing frame is wonky (and door frames in old houses are seldom plumb), you'll need to shim the hinges slightly. You can buy door shims on Amazon (sized according to the size of your hinge, generally 3.5") or just make them yourself out of thick plastic or thin metal.
You'll probably spend more time finishing the door (painting/staining) than you will installing it. I suggest pre-finished if you can get a match to your trim color.
Chris3Duke is offline   Reply With Quote
