Intermittent CPS Code - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-10-2015, 07:40 AM   #1
Lucas_SF
My Ride: 328i E46 1999
Angry Intermittent CPS Code
Hi!
In the last 4 months I'm having a big trouble with a Inlet Camshaft Position Sensor in my 328i 99.
I'm having the classic symptoms of a bad cam sensor:
- Loss of power, stalling, difficult to start the engine.
All of this symptoms comes up only with hot engine and it gets worse in hot summer days (The car almost don't run in high external temperatures after driving for a while)
I took it to a BMW specialist, he scanned the car an finds a Inlet CPS code (the same I got in my BMW 1.4.0 Scanner). The sensor has been changed and the harness rebuild. Problem still there.
Now the mechanic says that the problem lies in the ECU, but I'm not pretty sure of that.
Is that possible that a problem with the ECU have the only symptom of a CPS bad signal reception?
A ECU problem will come up only with hot engine?
I'm thinking that might be a faulty new sensor or something else, but I don't know if faulty sensors have this intermittent symptoms...
Any help would be great
Lucas_SF is offline   Reply With Quote
Old 02-10-2015, 09:28 AM   #2
lszlszx
My Ride: 1.8T, XC70
Did you install an OEM sensor?
Aftermarket sensors are notoriously unreliable.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 02-10-2015, 11:00 AM   #3
Lucas_SF
It's not an OEM sensor.
My first thought was buying another sensor (OEM), but the mechanic says that the problem isn't the sensor. Now I'm in doubt
Sponsored Links
Advertisement
Old 02-13-2015, 07:17 AM   #4
Lucas_SF
Up!
Old 02-13-2015, 10:20 AM   #5
Solidjake
Radar Specialist
Solidjake's Avatar
My Ride: '13 328i Msport 6MT
Aftermarket sensors should not be used for such a critical thing. Get an OEM one. I would not continue with anything else until the OEM sensor is used.
Old 02-13-2015, 11:34 AM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
^+1 OEM sensor.
It is not that the OEM sensors are so much better, the issue is non OEM sensors can be such garbage.
Example, may not be your exact case, but why does a sensor on ebay maybe cost $22 but the same OEM sensor from a decent supplier cost say $60?
Which one would you recommend and use?
There is a reason for the ultra cheap replacements and it is not usually a wise idea to consider these.
Old 02-13-2015, 11:59 AM   #7
Lucas_SF
That one was sold me like an OEM one, but the signal doesn't even show a square wave on the osciloscope, like it should be.
I'll return it to the store and get my money back.
My doubt is if a low quality sensor can show intermittent issues or it will not work at all...
Anyway I will buy an OEM one and see what happens.
Sorry for any english mistakes.
Old 03-27-2015, 12:48 PM   #8
Lucas_SF
Now the car is running with two new sensors - exhaust and intake side (both OEM this time). The VANOS unit was removed and it was full of oil sludge, so it was replaced by another one, clean and revised.
The camshaft variation is ok now.
BUT, the code still comes intermittently, with the same symptoms.
Now I have no clue of what might be causing this.
Any ideas?
Old 03-27-2015, 12:51 PM   #9
Solidjake
Radar Specialist
Solidjake's Avatar
I might not be correct but next step is the vanos and it's solenoids. Since you replaced the vanos then it might be the solenoids but there should be a fault code for that.
Old 03-27-2015, 01:40 PM   #10
Lucas_SF
I'm thinking about put the intake side solenoid in the exhaust side to see if the code changes to the exhaust side.
Will that work?
Thanks for the reply
camshaft position sensor, cps, ecu, loss of power, stalling
