Old 06-10-2002, 10:20 AM   #1
Chailo27
My Ride: A Car
Speaker Question?
Does anyone know what size is the rear speakers for the coupe? Are there any replacemts that just drop right in without modifying the brackets?
TIA
Chailo27 is offline   Reply With Quote
Old 06-10-2002, 11:57 AM   #2
bender
hammer talks like this
My Ride: 2006 Honda insight
Send a message via AIM to bender
Re: Speaker Question?
TIA
in the rear deck there 6.5, to change the tweeter you gotta use brackets...
Name:	rear panel back off.jpg
bender is offline   Reply With Quote
Old 06-10-2002, 12:00 PM   #3
Chailo27
My Ride: A Car
Re: Re: Speaker Question?
Thanks,
I just realize that the speakers says two OHMs. Can I just put any speaker in?
Old 06-10-2002, 12:18 PM   #4
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
they are not 6.5, they are 6" which is the closest you will get to the 160mm which is the factory size. There are companies which make 2 ohm replacements, such as Coustic for example, so you don't put too low of a load on the amp. However, this is of no benefit unless you replace the factory amp because the rear's are used for midbass purposes, so replacing it with a full range speaker will not get you your desired results. The crossover is built into the amp.
guest1016 is offline   Reply With Quote
