PA Soft 1.4 for Dummies - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Old 07-23-2015, 04:37 PM   #41
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
PA Soft for 20 Pin E46 versions
I have a question for those e46 owners that have both the 20-pin round OBD connector under the hood and the standard 16-pin connector in the footwell.
Several years ago at Bimmercruise in Toronto I had my e30 with me and the guy parked next to me had a 1999 323 or 328. At that time I used BMW Scanner 1.36 and had it with me on a laptop. The guy with the old e46 asked me to turn off his DRL's. He had both ports (engine & footwell) I recall hooking up to the footwell and accessing the LKM but not being able to read all the modules especially the DME. I can't recall exactly but I think to talk to the DME via BMW Scanner 1.36 I had to use the port in the engine. I used a connector like this image to attach to my regular 1.36 OBD connector.
If I remember correctly BMW Scanner 1.36 would talk to some modules through the engine port and others thru the footwell port.
Does anyone who has both ports in their e46 have a definitive answer for BMW Scanner 1.4.(v9) which is the main version used today. Which modules can be read via which port connector and do you need to use the adapter imaged above. Is there a workaround to this by re-configuring the 16-pin pinouts to use a single connector?
BMW-North is offline   Reply With Quote
Old 07-23-2015, 07:15 PM   #42
SilberVogel
My Ride: 2002 330Ci Conv.
I don't have any personal experience with this, but have seen the pins under the hood jumped for use with a single connector. According to TerraPhantm (here), "If you do this, you can access every module from the OBDII port":
Source: http://forum.e46fanatics.com/showthr...5#post16590185
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 07-23-2015, 07:28 PM   #43
BMW-North
Thanks Silbervogel - that'll work - then just screw the cap back on and forget about that port and you won't need the adapter I inserted in post #41.
Sponsored Links
Advertisement
Old 07-24-2015, 03:34 AM   #44
LocoCan
My Ride: 2000 323i sedan
Well..
Jumpering the pins as in the above post worked for me. The cap have pins which fit into the socket. I was going to permanently jumper the pins in the cap so when accessing the footwell OBD2 socket, I won't have to play around with the socket under the hood.
I hope that was a helpful explanation.
LocoCan is offline   Reply With Quote
Old 10-04-2015, 03:04 AM   #45
Huajiachicat
My Ride: 2006 BMW 325Ci
Can't get DME Live data either
2006 325CI
other problems: can't write car odo into dme, car was recognized as 323ci
There is something with PA Soft and Live DME data.
I have tried using PA Soft on a number of cars and Live DME take is always greyed out and the button is not active.
I believe there are only some DME's that PA Soft can read Live DME data on.
So I would like to know what cars - year, model and DME people are able to get Live DME data for with PA Soft.
As useful as the Live DME data may be using PA Soft, also note that a generic OBDII that supports Live/Realtime data is a far more useful tool than PA Soft for drivability issues. Smart phone/tablet Apps are far more useful for drivability at the end of the day.
Huajiachicat is offline   Reply With Quote
Old 10-04-2015, 05:20 AM   #46
vaah
My Ride: E46 03 325i
2006 325CI
I can get my live data feed, car is e46 325i 2002.
Sent from my SM-T705 using Tapatalk
vaah is offline   Reply With Quote
Old 10-04-2015, 04:13 PM   #47
Huajiachicat
I use the same scanner and the same computer to scan my friends car: 2002 X5 3.0i, I got the live data.
I think the facelift (post 2002) E46s has an upgrade ECU version that PA soft doesn't fit this version very well. I believe the software itself is OK, but the difference in cars cause this problem.
Old 10-05-2015, 01:12 AM   #48
Huajiachicat
I have realized that the DME version of my car is MS45. I think the latest DME version the PA Soft support is MS43, Is anyone figure out how to get the PA Soft done on MS45?
Old 10-05-2015, 03:25 AM   #49
vaah
How do i know my dme version? My car is facelifted by the way.
Old 10-05-2015, 03:26 AM   #50
grimma
My Ride: 323ci 1999
Hello,
I am sorry to interupt but can I use this software to cycle my ABS pump on my 323 ci 1999? if I can I would buy one!
Thank you!
grimma is offline   Reply With Quote
Old 10-28-2015, 04:27 PM   #51
LouE39
My Ride: E39 525 tds
Hi everyone
Have have altered my ews with pa soft 1.4..
Now I cant go back to the original configuration,
What I did is I went into EWS/Coding data/setting and manufacture data
https://drive.google.com/file/d/0ByV...ew?usp=sharing
It was on "As EWS II (Version 2) and I changed it to EWS III (Version 3), thinking if anything goes wrong I could change it back.
But it wont let me change it back and the wont start.
Anybody have any idea how I can get out of this one
Thanks in advance
LouE39 is offline   Reply With Quote
Old 11-03-2015, 12:39 AM   #52
smgbimmer
My Ride: E46 MSport
Hi guys any idea how to use the mileage offset setting? Thanks
smgbimmer is offline   Reply With Quote
Old 11-27-2015, 03:56 PM   #53
franz
My Ride: 03 330i
Has anybody gotten this to work with Windows 10? If so I could use your advice!
franz is offline   Reply With Quote
Old 11-28-2015, 01:25 AM   #54
Martialartsblac
My Ride: 2002 325ci
Send a message via Yahoo to Martialartsblac
I had to swap my guage cluster out ( my wife jump started it from the battery and fried it) now my dsc dosent work. Pa soft says no can bus error and eeprom error. Can pa soft fix this?
Mods: 2002 325ci led tails-yellow hid fogs-Miniture schnauzer in back seat
Martialartsblac is offline   Reply With Quote
Old 11-28-2015, 08:46 AM   #55
wasp9166
My Ride: 04 330i jet black
i jump start the batt in trunk all the time
anyhow, it seems the temp gauge re program is the most useful of this soft , what else is a must do with this?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 11-28-2015, 02:05 PM   #56
Martialartsblac
My Ride: 2002 325ci
You've been fortunate. When I searched this issue there was a plethora of stories like mine.
Old 11-28-2015, 02:33 PM   #57
wasp9166
no kidding , huh , will have to read up on proper jumping i guess
Old 12-07-2015, 04:35 PM   #58
t_g_farrell
My Ride: 2000 323i
Stoopid newbie question here. Is this the software I would use to reprogram things when swapping in a manual for an auto tranny?
Seems I need BMW programs to modify the DME as well. Easy to get and use or dealer only?
t_g_farrell is offline   Reply With Quote
Old 12-07-2015, 05:05 PM   #59
franz
My Ride: 03 330i
I think PA Soft should be able to get all of that done for you.
Old 12-07-2015, 09:01 PM   #60
mleindek
My Ride: 2009 X5
I guess the P.A Soft has that option, never swapped my transmission so I don't know if you need something else, but there is an option somewhere that you can select auto or manual trans. The DME you can make it with the P.A. Best 50 bucks ever spent on my car.
mleindek is offline   Reply With Quote
coding, guide, manual, pa soft, tutorial
