Sponsored by The Tire Rack
Old 08-24-2003, 10:01 PM   #1
Bimmerman330
My Ride: 330Ci,
Send a message via AIM to Bimmerman330
eagle one mag lite wheel cleaner messed up my rims.
as some of you might know, my rims got really f'ed up after using Eagle One Mag Lite cleaner. THe finish is pretty much gone and the previous brake dust is glued on the rim or something. It looks like crap and i have to scrub with clay bar for about 15 minutes in one area to get a portion off. (about 3 inches) I'm probably gonna get them rechromed or repaired but...i'm just asking for opinions, should i write a complaint letter to Eagle One or did i just screw up?
Bimmerman330 is offline   Reply With Quote
Old 08-24-2003, 10:04 PM   #2
Orient330iNYC
Flying Monkey Herder
My Ride: 04 S60R 6MT, 01 330i
isnt mag cleaner for bare, machined alloy rims?
if the stuff you used is what i'm thinking of, i'm not surprised the acid ate the clearcoat....
rule of thumb, if you wouldnt use it on your paint, dont use it on your rims....
Orient330iNYC is offline   Reply With Quote
Old 08-24-2003, 10:05 PM   #3
GrkBeemer82
My Ride: 2001 325i
Send a message via AIM to GrkBeemer82
Orient's right
Current Mods:
18" Mutecs
Shark Injector
ITG CAI
Supersprint Exhaust
RE Pulleys
330i Inlet Tube
H&R Sport Springs
Koni Adjustables
Brembo Drilled Rotors
Pagid Dustless Pads
BMP Strut Bar
HID Lights
Haman Eyelids
M3 decklid spoiler
Clear Corner Lights
Haman Shadow Grill
Future Mods:
Dinan Trans Sftwre & Throttle Body
GrkBeemer82 is offline   Reply With Quote
Old 08-24-2003, 10:07 PM   #4
Bimmerman330
My Ride: 330Ci,
bare, machined alloy rims....argh...i'll start using soap and water from now on. i think imma go get it repaired. but thanks for the quick responses.
Old 08-24-2003, 10:19 PM   #5
Frantic1
My Ride: 2004 330 Ci
Groits wheel cleaner works really well and doesn't harm anything. Brake dust rinses off really nice. I never even heard of Groits until I started visiting these boards .
Frantic1 is offline   Reply With Quote
Old 08-24-2003, 10:58 PM   #6
Orient330iNYC
P21S gel works well too... a little pricey...
i've had good luck with meguirs hot wheels...
just make sure your brakes (and wheels) are cool before using any cleaner. the heat can cause the cleaner to dry onto the wheels, then, uhoh...
I'm contradicting myself, but i use a a pressure washer and soap on my rims nowadays...
super clean real fast, and after using the washer for 1yr+, no damage.... aside from the time i blew a loose wheel weight off into the neighbors yard...
Old 08-26-2003, 03:44 AM   #7
Bimmerman330
My Ride: 330Ci,
dang..i feel like an idiot now. but thanks for the advice and info guys. where do u get the pressure washer?? and wut exactly is it?
Steel Grey 330Ci
Mods: none
