How reliable have your FI setups been?? Advice? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-24-2016, 02:03 PM   #1
Jamespie
My Ride: 330ci
Hey guys i have a 2002 330ci manual trans with 180k miles. Not a problem with the engine ever. Its been very well taken care of. I was thinking about getting a TT turbo kit. My concern is how reliable FI m54b30's are with stock internals?
How reliable have your setups been and do you recommend SC or turbo? Thanks!
Jamespie is offline   Reply With Quote
Old 01-24-2016, 03:27 PM   #2
Cheapbimmer
My Ride: M3
I do not have a fi'd bmw engine, nor have I ever done any kind of work like that to a German car. I have however played around with some Hondas and American v8's in the past.....so take my advice with a grain I guess.
At 180k clicks I wouldn't go adding tons of horseponnies, I'd most likely begin the search for a low mileage engine. if the body and interior is in good shape, I'd go hunting for a wrecked m3 and swap out all the good stuff. (Engine, transmission, diff, cluster, ect.) Most likely you could go this route substantially cheaper than sc the car. Also you won't be dealing with all the tuning crap that goes along with fi....
Just my 0.02
Cheapbimmer is offline   Reply With Quote
Old 01-24-2016, 04:39 PM   #3
Jamespie
My Ride: 330ci
Just my 0.02
I was looking into s54 swap and it looks like a headache! All the special wiring and i cant find any good guides on DIY
Sponsored Links
Advertisement
Old 01-25-2016, 03:12 AM   #4
Davconelectric
My Ride: 2 dog powered sled
Just my 0.02
Lol. What tuning crap? He looking at buying a proven kit.
Davconelectric is offline   Reply With Quote
Old 01-25-2016, 05:33 AM   #5
BKMrSteel
My Ride: 99 328i
You still need to tune for your engine...
BKMrSteel is offline   Reply With Quote
Old 01-25-2016, 06:17 AM   #6
daniel_f.
My Ride: 330iC
The kit does include a tune, which is probably the best you can find for that setup.
Old 01-25-2016, 08:05 AM   #7
Jamespie
My Ride: 330ci
I know the kits are proven. Im worried about engine reliability and how much hp stock internals can handle
Old 01-25-2016, 08:52 AM   #8
daniel_f.
My Ride: 330iC
Probably much more then you will gain by the kit I donīt know how its handled in US, but in EU the seller of such a kit is responsible for such kits and if the engine blows due to imperfections, like the tune being to advanced, then you can pull him to court!
Old 01-25-2016, 12:21 PM   #9
dbarton62
My Ride: 04Z4R VF 12PSI
My .02
My M54 has been supercharged for 3 years now. I have increased the boost incrementally each year with zero "mechanical issues"
Before you seriously consider the SC route be sure the base engine s running at its best.
Check
1 Vanos rattle
2 Disa valve operation
3 Vacuum leaks
4 CCV
5 O2 sensors
6 Cooling system is up to snuff
Do some searching and educate yourself on these items
Also decide up front whether you are going to add more enhancements ie header and perf. exhaust. The kit supplier will adjust the tune for these items(that is what VF Engineering did for me)
04Z4R 3.0 6 speed VF supercharged,Tial BPV,Ceramic coated Bimmerbrakes header, megan motor&trans mounts,42 design catch can, custom intake ducting,2.62 blower pulley,pre and post S/C WMI,CDV delete ,custom strut bar,3.64LSD, H&R anti roll bars, adjustable Hotchkis end links.Eibach Pro Kit,Koni Yellows. Carbon dipped interior.
dbarton62 is offline   Reply With Quote
Old 01-25-2016, 05:46 PM   #10
triksterut
My Ride: 05 M3 Vert
I've had my AA kit installed since April 2012 and about 10k miles or so. It's been flawless - minus me having to replace the clutch since it couldn't cope
triksterut is offline   Reply With Quote
Old 01-28-2016, 10:49 PM   #11
lab rat
My Ride: '02 330iT
About 40k miles on twinscrew SC 331whp. The engine had about 140k when I installed it.
Do a compression test and see what's up.
Worst case scenarion just change the block if you blow it up.
Because sleeper
Old 02-01-2016, 09:16 PM   #12
MachRc
is divorced
MachRc's Avatar
My Ride: 2003 Technik S1 M3
"Can it be, we've run out of time? You're alive.. ohhh? In these streets we living to die. When it's your time, you will know..
..cause it ain't hard to tell. "
MachRc is offline   Reply With Quote
Old 02-02-2016, 04:23 PM   #13
jdjg
My Ride: e39, m52tub30
2 years, like 80,000 kilometers, 79mm pulley, 325whp, 0 issues with my motor
(ESS TS2+ SC)
jdjg is offline   Reply With Quote
Old 02-02-2016, 07:23 PM   #14
Rogue Pyro
My Ride: 2003 325i
Seriously long blocks are so cheap now.
Rogue Pyro is offline   Reply With Quote
Old 02-03-2016, 09:28 AM   #15
MichaelStar
My Ride: 325 Touring
I just added a s/c to my engine at 153k miles. Took care of regular issues (DISA, OFHG, Vanos) and I don't expect any issues.
MichaelStar is offline   Reply With Quote
Old 02-03-2016, 09:56 AM   #16
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
I would recommend having a compression and leakdown test performed with that type of mileage before going F/I. Whatever parts are weak are going to quickly show. Make sure you have a back up car if this is your daily
Viral@ActiveAutowerke is offline   Reply With Quote
2002, 330ci, sc, supercharger, turbo
