Old 05-13-2016, 09:08 PM   #1
evanr614
My Ride: used 2 have 2 pedals
evanr614's 328Ci progress thread (updated 5/26/17)
Welp, it's officially a "build" thread. I like to have this as documentation on the changes made to my car over time. (Updated 5/26/2017)
Recent Photos
Maintenance
-Full cooling system overhaul including new tensioners.
-VANOS Seals + Valve Cover gasket
-Oil Filter Housing gasket
-Full CCV overhaul + re-seal DISA
-Electric fan conversion (Volvo module transplanted to new BMW shroud)
-Complete power steering line overhaul
-Oil level sensor
-Intake/Exhaust Camshaft Position Sensors
-Fuel Pump
-Final Stage Resistor
-Aluminum water pump/power steering pulleys
-Wheel stud conversion kit
-Hawk HPS rear brake pads w/ Zimmerman rotors (front brakes to be overhauled)
-Windshield cowl replacement + cabin filter replacement
-Full transmission fluid flush using Pentosin ATF 1 w/ new pan gasket and filter (OLD)
-Differential drain and fill with Redline 75-90
-Brake fluid flush with "Genuine" BMW fluid
-Ambient Temperature sensor plus splash shield replacement
-Siemens VDO Mass Air Flow sensor replacement + all new intake boots
-Front/rear sway bar end links
-Driveshaft flex disk/CSB
-Replaced both rear axles/bearings + dust shield replacement (GKN and F A G)
-Rear headlight level sensor repair (broken link)
-OEM F A G Front Hub bearings
-Rear main seal replacement
-Oil pan gasket replacement
-Turner Motorsport reinforced oil pump nut
"Modifications"
-ZF 5 Speed swap, all brand new shifter components, E60 shift lever, Valeo single mass flywheel conversion, UUC stainless steel clutch line
(Shift pin repair for all gears, input/output/selector shaft seals, Redline MTL)
-Turner Motorsports reinforcement kit welded to rear subframe floor
-Mason Engineering floor support bar (runs a stud from the bottom of the rear subframe mounting points all the way into the trunk and then bolted to a brace)
-Ground Control Coilover Conversion w/ Koni Yellow front shocks and GC street camber plates
(5" #425 in the front, 5.5" #475 in the rear)
-Rob43 9 way adjustable rear shocks
-Revshift 95A Subframe bushings
-OE Lemforder differential bushings
-OEM M3 Transmission/Engine Mounts
-OEM M3 Strut brace
-Powerflex FCABS
-90A front/rear sway bar bushings
-90A RTABS
-90A trailing arm ball joints (all 4 upper and lower)
-Adjustable rear lower control arms w/ poly bushing
-TopSpeed stainless steel headers (titanium wrapped)
-Open loop EU2 tune (post cat o2/secondary air pump delete)
Cosmestic
-M Tech II front/rear bumper + side skirts (aftermarket front/OEM rear bumper and sideskirts
-3M Gloss Atlantis Blue full vehicle wrap
-Matte black finisher trim, roof rails, and license plate overlay
-Full interior trim wrap / armrests rebuilt and wrapped
-All new center console pieces / OEM Aux routed to euro tray
-Full interior LED kit + license plate lights
-Amber clear corners / tailights (the car came with clears)
-Facelift trunk lights
-18" BBS LM Reps (18x8.5 ET 30 18x9.5 ET 35) (SOLD)
-OEM E92/E90 M3 winter package wheels - Style 270's 18x8 ET 20 squared
-Complete black headliner swap from M3
-ZHP Knob
Subframe Saga
So once I found out I needed to take care of the subframe floor in my 2000 328Ci I decided to pretty much swap anything else I could while the work was being done...I've been wanting to make a thread to show what I've done. The car is currently being finished up at the shop and will be picked up monday so I will update with pictures of my new wheels/suspension setup and details on how I went about tackling the subframe issues.
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 05-13-2016, 10:31 PM   #2
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Nice
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 05-14-2016, 09:18 AM   #3
orb
orb's Avatar
My Ride: 325Ci
Interested to see how stiff that will be. That's a lot of poly lol
orb is offline   Reply With Quote
Old 05-14-2016, 10:18 AM   #4
KaktusJaque
My Ride: 2003 325xi
How much have you put into this project? Very nice indeed.
*KJ---Don't Believe Everything That You Think! *
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Clean Your Dirty Wheels
2003 Touring 325 XiT (KJ's Ride)
2004 Coupe 325 Ci (Mrs. KJ's Ride)
KaktusJaque is offline   Reply With Quote
Old 05-14-2016, 10:19 AM   #5
evanr614
worst case scenario i turn it into a racecar right? no but i'm interested also haha
Old 05-14-2016, 10:21 AM   #6
evanr614
upwards of 2k or so if you include the ground control kit. that's not including the subframe repair labor of course but the body shop owner is giving me a really nice deal because i've been going to him for 2-3 years now.
Old 05-14-2016, 01:19 PM   #7
Nicker
My Ride: 323ci
I'm loving this, but also dreading doing this, having a 323ci, im pretty sure it's not if, but when my subframe might explode.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 05-14-2016, 01:42 PM   #8
KaktusJaque
My Ride: 2003 325xi
evanr, is that your car in your sig? What wheels are those?
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Old 05-14-2016, 05:41 PM   #9
evanr614
Yep, better to take care of it sooner than later. I only had a small crack in one mounting point but who knows much longer the floor would've held up.
Yes, it is an older pic. I got some new wheels. They are Style 162's off the E90. I loved them.
Old 05-17-2016, 08:49 PM   #10
evanr614
Rear End Restoration Picture Thread
Got the car back today. Didn't get any pictures of the underside yet but here's a picture of the Mason Engineering floor support bar.
the car drives great so far however it looks like he damaged the O2 sensor when wrestling to get the exhaust off. He is going to take care of it. Currently pulling a P0141. I also think the e brake could be dragging (which he was aware that it might be possible) so unfortunately I'll be taking the car to my Indy on his behalf to check that over.
I did some ride height adjustments while I have the car so I'll get some full pics of the car up after everything has been sorted and I get it aligned.
Old 05-18-2016, 07:45 AM   #11
lllRazorlll
Modded ///Member
My Ride: '00 328i
Attachment 632220
Those two white square patches where that metal tube comes out from is where the subframe has been reinforced?
Old 05-18-2016, 09:37 AM   #12
evanr614
Sort of. As a part of the turner kit you go in through the trunk and do some work to the spot welds, as shown on page 4 and 5 of this PDF.
https://1c2a8a2161d644d95009-22d26b3...nforcement.pdf
The Mason bar I have installed is an extra measure of reinforcement.
Old 05-24-2016, 03:00 PM   #13
evanr614
took some quick photos today. there's no where cool to take pictures around where i live, so trees and leaves will have to suffice for today...
Still haven't fully dialed in the ride height on all four corners, the camber in the rear is a little excessive but i dont rub. Getting the car aligned thursday.
I still want to get some pics from the under the car of the rear end.
Old 05-24-2016, 03:35 PM   #14
lllRazorlll
Modded ///Member
My Ride: '00 328i
Nice. What camera do you have?
Old 05-24-2016, 03:36 PM   #15
evanr614
D90. It's kind of a dinosaur now. I kinda kicked the hobby of photos when I got my E46...:/
Old 05-24-2016, 06:08 PM   #16
zander271
My Ride: 6spd ZHP/5sp XI
You car looks great btw Glad to hear you have it pretty much back together.
Sooooo Evan...what tool did you use to remove those Sub-frame bushings.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 05-25-2016, 08:00 AM   #17
evanr614
Thanks! That lovely 300 some dollar Koch tool. Rented it on here. For the diff bushings I bought the Koch tools myself and now they're just sitting around. In total took about an hour to get all 7 bushings pressed out when Indy shops wanted 5-6 hours!
Old 05-25-2016, 08:33 AM   #18
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Beautiful Evan! It's a little low for my tastes but everything else is just stunning---the wheels, the color, the detailing. Perfect. Love the LMs (they are LMs, right?) so much better than the E90 wheels, which looked too chunky for me. Keep it up!
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 05-25-2016, 08:49 AM   #19
austine46
My Ride: m54b25
Wow man good stuff right here, hows all that poly feel while driving?
everyone's a critic
FS: coupe facelift xenons, stock headers no cats, stock sport suspension for coupe, oil separator, non m coupe lip
austine46 is offline   Reply With Quote
Old 05-25-2016, 10:21 AM   #20
evanr614
Thank you! LM reps
So far so good with all the poly. It's doesn't feel much stiffer than from what it felt like before I got this all done to be honest.
