Help me finish my engine swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 11-18-2016, 02:58 PM   #1
Mario0617
My Ride: 2003 330i
Hey guys
Just finished all the mechanical work of a 2.5 to 3.0 engine swap. I'm now trying to get the ecu recoded properly. I have winkfp working and edited the zusb value, but am now trying to get the adaptations and such reset. I'm not sure which software is easiest to use for this.
I tried getting inpa set up, but it's completely frustrating me. Are there any easier to install options?
Mario0617 is offline   Reply With Quote
Old 11-18-2016, 03:31 PM   #2
mr ilia
My Ride: 2004 BMW 325i 5spd
Are you saying you already updated the software from 2.5 to 3.0? If you did the car should be fully running.
Are you looking for throttle adaptations? Found this procedure on this website.
Here it is:
E46 Resetting Throttle Response
Over time your BMW e46 wil adapt to your driving style. Can you remember the days when your car would feel fast and spirited and jump when you touched the peddle? Have you lost that feeling? Well, it's not totally your fault. It's fun to go fast, but who doesn't like to get 27-28 Mpg? You can change back to a default setting if you wish.
Here's the steps for an e46. They are simple and easy to follow.
First, with the key removed, sit in the driver's seat and insert the key.
Turn the key to position "2". Position "2" is one position before the car engages and starts.
Wait 10 seconds and then turn the key back to position "0", which is the initial position.
Once again wait 10 seconds and then start the car up.
You should now have your throttle response reset and your driving pattern from this point on
will dictate how your throttle response adapts.
Over time your throttle response will once again become lacking and another reset will need
to be performed. It is recommended that this be performed every 3-6 months if you feel the
need to have your spirited car back.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 11-18-2016, 04:48 PM   #3
Poolman
My Ride: 525 BMW
An independent auto shop, using Autologic should be able to reflash the system for you , for around a hundred bucks.
Poolman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-19-2016, 02:59 PM   #4
iowna330xi
My Ride: 323i Turbo
Inpa is surely the easiest way to reset adaptions. At least when it's running properly. What errors are you getting during your inpa install? I'll see what I can do to help
iowna330xi is offline   Reply With Quote
Old 11-19-2016, 03:55 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Resetting adaptations is a bit over rated. Note the word adapt is within adaptation. They will change without being forced, it just saves shops from having to drive the car to see if a repair worked properly.
If the engine does not run well now, resetting the adaptations rarely will solve other problems.
Old 11-19-2016, 06:35 PM   #6
Poolman
My Ride: 525 BMW
The dme has to be flashed again, and set up for the 3.0 engine ,instead of the 2.5. Adaptations has nothing to do with this. Both engines use the same DME, but the 2.3 engine uses a different one. also the 540 V8 uses a different one. You are either going to have an indy do the flash for you, or the dealership , which would be costly.
You can install the engine and hook every thing up. The engine and the car will run, but to get all the benefits of the larger displacement from your new 3.0 engine,it has to have the flash performed.
Old 11-20-2016, 08:23 AM   #7
BaliDawg
Ombak besar hari ini!
My Ride: E24 E32 E39 E46 E84
Originally Posted by Mario0617 View Post
Hey guys
If you just updated the DME using WinKFP, then you need to clear error codes and reset adaptations before attempting to start the engine. I use BMW Scanner 1.4 for that.
From the top menu: Units, DME, Reprogramming, EWS-DME adaptation
///Mmmmmm...
dme, ecu, engine, inpa, swap
