Old 03-20-2017, 02:35 PM   #1
Tdavis13
My Ride: Bmw 330xi
Please help anyone!
Have 4 codes being thrown
Intake camshaft position sensor
Both cams over retarded
And maf
Changed the intake cps and fuel filter - pressure regulator and car won't start.....hasn't turned over since before I changed filter please help
Tdavis13 is offline   Reply With Quote
Old 03-20-2017, 03:08 PM   #2
YoitsTmac
My Ride: 328Ci
Intake cam sensor can make starting hard to impossible
YoitsTmac is offline   Reply With Quote
Old 03-20-2017, 03:27 PM   #3
Tdavis13
My Ride: Bmw 330xi
I put the new one on tho shouldn't it start?
Old 03-20-2017, 03:28 PM   #4
YoitsTmac
My Ride: 328Ci
Will it start if you spray starter fluid in the intake?
Old 03-20-2017, 03:31 PM   #5
Tdavis13
My Ride: Bmw 330xi
I could use a little gas....all I got rn where should.i spray it in?
Old 03-20-2017, 03:57 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
1. Has not started since before I changed the fuel filter.
2. Has not started since I changed the fuel filter.
If the correct statement is #2, then the fuel lines may be connected to the fuel filter incorrectly and/or the engine is flooded.
For a flooded engine:
http://forum.e46fanatics.com/showthread.php?t=1063462
http://forum.e46fanatics.com/showthread.php?t=1069117
http://forum.e46fanatics.com/showthread.php?t=1112112
http://forum.e46fanatics.com/showthread.php?t=1117576
http://blog.bavauto.com/17656/it-hap...king-no-start/
Old 03-20-2017, 03:59 PM   #7
Tdavis13
My Ride: Bmw 330xi
Yes #2 I've tried for 3 days to start with no avail it seemed as tho it wanted to just won't actually start
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 03-20-2017, 04:04 PM   #8
Dave1027
My Ride: '06 IR zhp coupe
Maybe you got a bad fuel filter? Try putting the old fuel filter back on
Old 03-20-2017, 04:07 PM   #9
Tdavis13
My Ride: Bmw 330xi
I've got gas coming out after filter and at fuel rail ik that for sure
Old 03-20-2017, 04:11 PM   #10
jfoj
Engine is flooded assuming the coils and injectors are triggering.
You may need a Noid light and a spark tester to verify if the coils and injectors are triggering.
Make sure the fuses in the DME box are good as well.
Old 03-20-2017, 04:13 PM   #11
Tdavis13
My Ride: Bmw 330xi
So I should remove plugs and let dry or try to turn over with pedal to the floor?
Old 03-20-2017, 04:51 PM   #12
Tdavis13
My Ride: Bmw 330xi
Def has spark and gas just tested both....there is a pulsating noise coming from airbpx does that give any clues?
Old 03-20-2017, 05:00 PM   #13
JFM330i
My Ride: 2002 330i
Maybe the battery is weak from all these attempts, get a jump
2002 330i auto
1999 323i 5 speed
2013 Úlantra 6 speed
2010 rogue AWD
2003 eclipse GTS 5 speed
1995 celica st 5 speed
2007 gsxr 750.....track weapon!
JFM330i is offline   Reply With Quote
Old 03-20-2017, 05:03 PM   #14
Tdavis13
My Ride: Bmw 330xi
Not a bad idea
Old 03-20-2017, 05:04 PM   #15
Tdavis13
My Ride: Bmw 330xi
I've been having it on a trickle charge cuz I run it right down with all these attempted starts
Old 03-20-2017, 05:09 PM   #16
JFM330i
My Ride: 2002 330i
Does the trickle charger go to green or does it stay in the Orange? Might need a stronger charger, a jump from another car or a new battery. How old is the battery?
2002 330i auto
1999 323i 5 speed
2010 rogue AWD
Old 03-20-2017, 05:11 PM   #17
Tdavis13
My Ride: Bmw 330xi
Not sure it's a bmw battery and the window has a green light in it on battery
Old 03-20-2017, 05:19 PM   #18
jfoj
Foot to the floor with a fully charged battery, follow the links I provided above, after the 3rd attempt the engine should kick.
Old 03-20-2017, 05:20 PM   #19
Tdavis13
My Ride: Bmw 330xi
Ok thx I'll try it now
Old 03-20-2017, 05:54 PM   #20
Tdavis13
My Ride: Bmw 330xi
With foot to floor I get a real strong has smell
