Old 03-20-2017, 06:07 PM   #1
1100russ
My Ride: 2002 330i
Tranny fluid advice
Ok guys, I've searched and searched and found some answers but I don't really like the answers lol. First off, it's an 02 330i auto (ZF) with 125k miles. What fluid should I use? I have seen valvoline merc V which I can't find locally, castrol transmaxx which I don't trust (don't like the idea of using an atf non specific fluid) or go to a dealer and pay anywhere from 15 to 30 dollars a quart for the esso type stuff. Who has used what, did it work well and is it still working/how many miles did you get? Thanks. I love this car and I want to drive it a long time.
1100russ is offline   Reply With Quote
Old 03-20-2017, 06:12 PM   #2
Darios e46
My Ride: 2003 325i sedan
You could always buy the oem fluid online for cheaper know ecs sells full service kits for a pretty good price
https://www.ecstuning.com/b-assemble...pwEaAsE18P8HAQ
Darios e46 is offline   Reply With Quote
Old 03-20-2017, 06:17 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
Dexron is everywhere and dirt cheap. Previously posted on Bimmerfest -
Originally Posted by cvx5832
My take, use Dex 3 or Dex 6, whichever. If it's an E46 auto, choose whichever and call it a day.
The GM takes Dex3 or Dex6 for obvious reasons.
The ZF can take Dex3 or Dex6 based on personal experience. I have 117k miles on Dexron with the ZF, 33k of that on Dex 6. For what it's worth I use Redline, change it every 45k and it comes out cherry red every time.
In cold weather (below 35degF) I notice the ZF with the Dex 6 shifts quicker but shifts like my other ZF with the Dex 3 after it warms up.
cvx5832 is offline   Reply With Quote
Old 03-20-2017, 07:36 PM   #4
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Why are you recommending Dexron in a ZF transmission? It's not approved by ZF.
///Mmmmmm...
Old 03-20-2017, 07:37 PM   #5
BaliDawg
I have the same ZF transmission in my E39 and use Valvoline Import Multivehicle.
http://www.valvoline.com/our-product...smission-fluid
You can use any of these:
Valvoline Import Multi-Vehicle
Valvoline Maxlife Multi-Venicle
ZF Lifeguard5
Pentosin ATF1
Febi No. 14738
Fuchs Titan 5005
Redline D4
Mobil ATF LT71141
///Mmmmmm...
Old 03-20-2017, 07:49 PM   #6
jmo69
My Ride: 03 325xi 98 328is
Isn't Redline D4 a Dex compatible oil?
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-20-2017, 07:56 PM   #7
BaliDawg
This page lists the fluids it's compatible with, including Esso LT71141.
https://www.redlineoil.com/product.aspx?pid=51&pcid=9
///Mmmmmm...
Old 03-20-2017, 10:11 PM   #8
cvx5832
Originally Posted by BaliDawg View Post
I have the same ZF transmission in my E39 and use Valvoline MaxLife Multivehicle Import.
You can also use these: ZF Lifeguard5, Pentosin ATF1, Febi No. 14738, Fuchs Titan 5005, Redline D4.
Redline D4 is a Dexron 3 fluid
Old 03-20-2017, 10:16 PM   #9
BaliDawg
Yeah, it says Dexron III as well as LT71141.
///Mmmmmm...
Old 03-20-2017, 10:19 PM   #10
cvx5832
Because -
The first known successful fluid changes on the ZF 5HP19 was on Dexron
The Redline D4 you just recommended is a fluid based on Dexron spec
Because I have 117k+ miles of personal experience on Dexron
The factory may not recommend it, but from what I see it's an endorsement based on $$$ & liability, not fluid compatibility.
But as always, just my opinion. Feel free to follow ZF recommendation. Just sharing actual experience.
Old 03-21-2017, 01:03 AM   #11
BaliDawg
Because -
Well, I have very little knowledge on oil chemistry, so I only use those specifically stated as compatible or recommended. I spent some time hunting down the ATFs I listed with verified written support for ZF 5HP19 or compatible with Esso LT71141 for my own maintenance of ZF ATs.
There are a few oil experts on here so maybe they can offer more input?
///Mmmmmm...
Old 03-21-2017, 06:13 AM   #12
markusmarkus
My Ride: 2001 330Ci
No, it's a Dex4 fluid.
Old 03-21-2017, 07:40 AM   #13
BaliDawg
What? You joking? There is no Dexron 4 fluid.
There is Dexron VI (6) though, but D4 isn't that.
Did you read the D4 link I included?
It specifically states compatible with Dexron III and Dexron II.
///Mmmmmm...
Old 03-21-2017, 07:42 AM   #14
1100russ
My Ride: 2002 330i
Easy guys.......Just looking for recommendations. Especially from guys that have put alot of miles on certain fluids. I appreciate the ideas. All of them!
Old 03-21-2017, 07:53 AM   #15
BaliDawg
Nothing like an oil thread to get the debate juices roiling..ha ha ha.
You may still be able to get the original Esso LT71141 fluid from a BMW dealer. The ZF Lifeguard5 is the closest to that, but a bit pricey.
https://www.fcpeuro.com/products/zf-...-liter-lt71141
When I did my research some time ago, I found written support for each of the ATFs I memtioned in the earlier post and settled on the Valvoline.
///Mmmmmm...
Old 03-21-2017, 08:15 AM   #16
m_peterson6
My Ride: 330CI convertible
Just google "LT71141 equivalent" or "lt71141 compatible" and pick a brand. There are options from Castrol, Mobil, Valvoline, etc. Dexron/Dexron equivalent has been used in the ZF but it is no cheaper or easier to obtain than the fluid recommended by the manufacturer so I do not see why anyone would want to use it.
m_peterson6 is offline   Reply With Quote
Old 03-21-2017, 09:01 AM   #17
BaliDawg
I never knew about the MOBIL ATF LT 71141, as shown here. Will add it to the list!
http://www.mobil.com/english-GB/Pass...L-ATF-LT-71141
http://www.ebay.com/itm/Mobil-Esso-L...oAAOSwuxFYuAoy
Which Castrol ATF? I searched their website, read their data sheets, and couldn't find anywhere they said it's compatible with Esso LT71141. If you have a reference, please post it. Thanks.
///Mmmmmm...
Old 03-21-2017, 10:57 AM   #18
cvx5832
You have the goofiest posts sometimes. But in case you were serious, there is no Dex 4.
Old 03-21-2017, 03:38 PM   #19
mtnbimmer
My Ride: 325xi
KISS
ZF transmission, ZF Lifeguard 6.
mtnbimmer is offline   Reply With Quote
Old 03-21-2017, 04:19 PM   #20
SiVaE46
My Ride: 2003 325i
Zf6 is for 6 speed zf ? Zf5 for ours . I'm running Fuchs Titan - FCP euro lists a number of compatible fluids - and free shipping ....
SiVaE46 is offline   Reply With Quote
