Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 04-21-2017, 10:17 AM   #1
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
Wood Trim Restoration
Who here has actually restored their wood trim?
I did a search, but most that I could find was a simple mention of it among threads debating wood vs other trims.
I have a spare set (not sure it's complete at the moment) from my old 328i that I want to toy with. The wood trim on my car is in perfect shape, but I may want to do something different.
So, who has restored their trim? What have you used to clear it with and how did it hold up? Anybody end up with a thick coating like the factory coating?
My concern is that a standard evaporative finish will not hold up to heat very well and could end up all sticky and such. I'm just starting to noodle this, but I'm thinking at least a catalyzed finish would be required.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 04-21-2017, 10:37 AM   #2
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Not being a fan of the wood look, I would paint them instead.
///Mmmmmm...
Old 04-21-2017, 11:31 AM   #3
Geo31
Ironman
See, I love the wood look. Going to keep it.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 11:44 AM   #4
orb
orb's Avatar
My Ride: 325Ci
I polished mine with Plastix and the Porter Cable buffer, shined up nice. Are you thinking about removing the veneer? Not sure how well that'd work.
orb is online now   Reply With Quote
Old 04-21-2017, 11:47 AM   #5
Geo31
Ironman
I am. I am a woodworker and I'm thinking seriously of putting a different veneer on it. So, shining it up is not the problem (I have the PC buffer as well BTW). The issue is getting the right kind of finish on it.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 12:35 PM   #6
hitbyastick
My Ride: 2002 325i
Agreed. Non-wood look is less warm and more boi racery. A gentleman's car has wood trim in it.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 04-21-2017, 12:41 PM   #7
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Some of us prefer the term "sporty."
Really?
I kid; I kid.
George, I would think you might get some more tips on a woodworking/finishing site...
Current: '02 330i/5 • '10 Mazda5 • '72 240Z
Past: '85 GSL-SE • '95 540i/6'95 525i/5'86 635CSi/5 • '88 JZA70 • '86 4K quattro • '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 04-21-2017, 01:36 PM   #8
Geo31
Ironman
The problem with a woodworking site is the finish needs to not only survive, but not care that it's inside a hot (and sometimes cold) car, sometimes hot and cold on the same day here in Houston. Most normal woodworking finishes would not survive.
So, that is why I'm turning to the folks here. I know some have done it. Looking for info about success or failure.
Oh and FWIW, I think this is going to happen. Worst case scenario, I get the bodyshop two doors down from work to shoot a HEAVY coat of catalyzed clear so I can wet sand it and buff it. I'd rather apply the finish myself though.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 01:52 PM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
so what you're saying is you're a gentle man who loves warm wood
Old 04-21-2017, 01:56 PM   #10
elbert
My Ride: Chevy Beretta GTZ
Find an automotive refinishing supplies distributor, and you can get your own clear coat. You'll need a decent paint gun, as well as a good compressor (capable of at least 4-5 SCFM at the bare minimum).
The two systems probably easiest to find is PPG and Axalta Cromax (which used to Dupont products before that division got spun off). You're in Texas, so you probably won't have too many pesky environmental issues to deal with.
The supplier will have tech sheets on paint gun set up, or you can download them. The distributors I've worked with have been very helpful. All the paint fumes probably makes them very mellow
Not sure about wood veneer, but over a basecoat, start with two light tack coats, then several heavy wet coats. That should be enough for color (wet) sanding. I usually start with 800 grit, work up to 2000, then several machine compounds and polishes with my PC.
edit: if you have your neighbors clear the veneer, tell them you plan on wet sanding it. That way they will know what you plan on doing and will spray accordingly.
2004 E46 M3
2015 WK2 JGC
2001 E46 325iT
elbert is offline   Reply With Quote
Old 04-21-2017, 02:04 PM   #11
Alex323Ci
I see you're looking to restore the wood trim. I have always wondered since its real wood if one could sand and stain it again darker? Going to something more like the Birch Antracite.
Either way good luck with your project
Old 04-21-2017, 03:13 PM   #12
Geo31
Ironman
Wow! Thanks for that info! I'll check my compressor's flow rate tonight. I used to have a nice Binks gravity flow gun, but not anymore. I'll have to look around for something.
I think this is going to take shape soon.
Got something else coming for the interior, but I'll keep that under my hat until it gets here.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 03:15 PM   #13
Geo31
Ironman
Thanks!
I don't think you'd have a lot of success restaining. The problem is, the finish seeps into the pores of the wood so the stain would only cover the surface, and not seep into the wood. You'd have to do what I plan on doing... Sand off the old veneer, apply a new veneer, stain (probably dye really) and then finish.
If I pull this off I'll have a DIY with pics. Getting excited about doing this.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 03:18 PM   #14
Geo31
Ironman
This is the thread that got me interested in doing this:
http://forum.e46fanatics.com/showthr...rim+collection
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 07:38 PM   #15
asianisafish
My Ride: 330ci
It's real wood but there's a clear coat on top. Polish normally as you would car paint.
I left my arm test pieces in place and used a drill with a 3inch pad with m105 and m205, same with the dash board pieces
The center console i removed and did the same aswell.
I like my wood because it looks like $$$
asianisafish is offline   Reply With Quote
Old 04-21-2017, 08:18 PM   #16
Geo31
Ironman
Yes sir. I know it's real wood. I'm not interested in restoring what came from the factory. I was trying to be a little cryptic when I started this thread, but the cat is out of the bag. I want to sand everything down to the base, apply a new veneer, and finish it.
I was looking for info from people who actually refinished because figuring out the right finish to apply isn't straight-forward. I'll probably do the catalyzed clear coat though if I cannot come up with another solution.
I don't have my old trim at the house. I think it may be at my wife's old house (that we're getting ready to sell) and we'll be there tomorrow, so I'll find out. I may end up having to buy a sub-par set to refinish. That's OK though.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 04-21-2017, 10:21 PM   #17
elbert
In your shoes, I would buy a set of the plastic silver trim for cheap just to avoid having to sand through all that clear coat and the veneer. Probably save you a lot of time.
I would also spray paint them brown, like the factory wood trim, before applying the wood veneer, just in case there are any gaps.
2004 E46 M3
2015 WK2 JGC
2001 E46 325iT
Old 04-21-2017, 11:11 PM   #18
BaliDawg
Got a link for these?
///Mmmmmm...
Old 04-22-2017, 06:10 AM   #19
GCoop
My Ride: '04 325xi
Since the wood trim finish in my car started clouding up on some of the door pieces I have always wondered if refinishing the wood trim was possible and how much effort it would entail. I will be eagerly following the OPs journey and hopefully it will be documented here.
GCoop is offline   Reply With Quote
Old 04-22-2017, 11:39 AM   #20
evanr614
My Ride: used 2 have 2 pedals
ive always looooved that birch
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
