250 Functional Check TEV error code:( - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-19-2017, 12:56 AM   #1
az_330
My Ride: 330CI
Been battling this code for a while now. What exactly does it mean and how do I fix it? Just can't find much info on this one online.
2001 330CI w/ 5 speed.
az_330 is offline   Reply With Quote
Old 05-19-2017, 09:48 AM   #2
armenh7
My Ride: 2002 325i
Is this code from inpa? Is your check engine light on? If so, it's best to use an OBDII scanner and get the PXXXX codes.
armenh7 is offline   Reply With Quote
Old 05-20-2017, 04:12 PM   #3
az_330
My Ride: 330CI
Yes, from INPA.
No. This code does not show up on any OBDII scanners I've used.
Whenever I clear codes this functional TEV code comes back quick.... within a day or so of driving.
Old 05-20-2017, 09:43 PM   #4
armenh7
My Ride: 2002 325i
Yes, from INPA.
Do any codes show up though?
Old 05-21-2017, 11:17 PM   #5
az_330
My Ride: 330CI
1 day I'll have a code for SAP... I'll clear it and the next day I will get a code for TPS/MAF malfuntion. Clear that and the next day it's some other random thing.
But the functional check TEV code ALWAYS comes back. It is the only consistently recurring code.
I read something online about how the throttle bodies out of 2002 or older E46s have issues and can cause problems. So I purchased one out of a 2004 330ci with same part number and plan on swapping those out sometime this week when I have time. Not sure if it will make any difference but I guess we'll see.
Also plan on replacing both crankshaft position sensors and O2 sensors as preventative maintenance since those seem to be cause some problems with these cars.
Also not sure if it's related but I have a "surge" issue in 1st gear as well that is covered in this thread.... never figured that one out.
http://forum.e46fanatics.com/showthr...443&highlight=
Old 05-22-2017, 04:46 AM   #6
blarf
My Ride: 323i, 325iT, 540iT
http://lmgtfy.com/?q=bmw+tev
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 05-22-2017, 09:50 AM   #7
armenh7
My Ride: 2002 325i
forum.e46fanatics.com/showthread.php?t=741843
forum.e46fanatics.com/showthread.php?p=10101899
https://blog.bavauto.com/10512/bmw-f...reather-valve/
Old 05-22-2017, 08:30 PM   #8
az_330
My Ride: 330CI
I had no idea it was a relief valve to the fuel tank. Numerous google searches on the code came up nothing but guess I should have just searched the term TEV BMW.
I should mention that a few weeks back I was filling my tank but the gas stations pump malfunctioned and dumped gas EVERYWHERE because it did not click off. It just kept spewing gas even though my tank was full.
A day or two after that I got a incorrect purge flow code so I removed the charcoal canister box and let it air dry overnight. Reinstalled and the light came on once or twice more but hasn't come back since.
I think I got this now that I know what I'm dealing with. Thanks guys.
Old 05-26-2017, 11:27 PM   #9
az_330
My Ride: 330CI
Was about to purchase a new fuel tank breather valve when I saw this. Code 250 "purge function plausibility" relates to the reaction of the O2 sensors.... should I just go ahead and replace the fuel tank breather valve with a new OEM unit anyway? I plan to replace my O2 sensors eventually. Not sure what the exact problem is here.
Realized it's hard to read... it says "250 - Purge Function Plausibility - This functional check looks for the reaction of the O2 sensor signal during canister purging. The O2 sensor, Air Flow meter, and RPM values must react to the purging of the canister."
Old 05-26-2017, 11:31 PM   #10
armenh7
My Ride: 2002 325i
Was about to purchase a new fuel tank breather valve when I saw this. Code 250 "purge function plausibility" relates to the O2 sensors.... should I just go ahead and replace the fuel tank breather valve with a new OEM unit anyway? I plan to replace my O2 sensors eventually.
Well, you did mention that one time your tank got overfilled and fuel spilled. If it isn't too expensive and you don't mind buying it, why not? Maybe your O2 sensor doesn't fix it, so that'll be one thing checked off. Also, the searches for the code relates to the valve, so maybe the O2 sensors are a possibility, but the breather valve has a higher chance.
Just my $0.02
Old 05-27-2017, 02:45 AM   #11
az_330
My Ride: 330CI
Picked up a used tested and working OE one from ebay for $18. Hopefully that fixes it.
