Old 05-19-2017, 01:53 AM   #1
323toslow
My Ride: 323i, Passat Wagon
INPA: EWS Errors
Car: 1999 323i
Recently installed INPA, finally got around to checking the different modules with the program. When I checked the error memory from the EWS, there are four errors stored. Slightly concerning to me. Have had the car for two years and it starts and runs fine aside from the "can of marbles" sound the VANOS unit is making.
Can I safely clear the EWS error memory with INPA without fear of the car not being able to start afterwards? Only have one key for the vehicle too, and am not sure if it is # 1 2 3 or 4.
Output is in German, so I used a translator, this is what the EWS error memory shows:
E R R O R M E M O R Y R E P O R T
Date: 05/18/17 15:50:03
ECU: EWS3
JobStatus: OKAY
Variant: EWS3
RESULT: 4 errors in error memory !
16 Schluessel Nr.1 ungueltig wegen fehlerhafter Identifikation
(Key 1 invalid due to erroneous identification)
Error frequency : 5
sporadischer Fehler (Sporadic error)
3 WC-Toleranz erhoeht bei Schluessel Nummer 0
(WC tolerance increases with key number 0)
Error frequency : 1
15 Power-On-Reset
Error frequency : 31
statischer Fehler (Sporadic error)
19 WC-Toleranz erhoeht bei Schluessel Nummer 1
(WC tolerance increases with key number 1)
Error frequency : 3
Not sure what they really mean either.
323toslow is offline   Reply With Quote
Old 05-19-2017, 01:59 AM   #2
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Go ahead and clear it. It won't hurt anything.
scottjoh is offline   Reply With Quote
