Old 05-19-2017, 02:52 PM   #1
smhinto
My Ride: bmw e46 se 318i
Rear end rumble
Hello folks
I would appreciate any pointers on the following:
My year 2000 E46 318I Saloon has developed a rumble emitting from what appears to be from the drivers side rear wheel. This occurs on all road surfaces.
I have had both rear wheel bearings and brake discs changed about eight months ago. There is nothing stuck in the tyre and the Michelin PS3 tyres are only one third worn. There is also no indication of the wheel balancing weights missing.
I am making assumptions that it could be the axle half shaft is worn or maybe if the wheel bearings are tapered and need tightening, although there is no side to side play on the wheel.
Any help and pointers would be appreciated. Thank you.
Regards to all.
smhinto is offline   Reply With Quote
Old 05-19-2017, 09:38 PM   #2
fumigator
My Ride: 2000 328Ci
Bearing? Had to replace one around 200kmiles.
Sent from my LG-V410 using E46Fanatics mobile app
fumigator is offline   Reply With Quote
Old 05-20-2017, 08:01 AM   #3
markusmarkus
My Ride: 2001 330Ci
Do you now what brand of bearing was installed? BMW OE bearings are made by ***. SKF is a very good brand. Perhaps an audio recording would help.
Old 05-20-2017, 08:49 PM   #4
fumigator
My Ride: 2000 328Ci
No idea. Local indie.
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
