My 2003 330i ZHP S54 Swap Conversion - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 06-09-2017, 12:46 PM   #1
nextelbuddy
My Ride: E36 M3
I made a thread on ZHPMafia but on here ill just post swap relevant stuff.
Car Currently as of 4/28/2017
Car:
2003 BMW E46 330i ZHP
AKG Specific parts:
  • Rear Subframe Reinforcement Kit
  • Front Control Arm Bushing Set (60 mm), Poly 95A (E46 M3)
  • Group N Motor Mount Set, Poly 80A (E36, E46, Z3, Z4)
  • Differential Mount Bushing Set, Poly 75D – E46 (M3), Z4 (M)
  • Rear Trailing Arm Bushings Aluminum – Spherical Bearings (E36, E46, Z4)
  • Rear Subframe Bushing Set, Poly 75D (E46, Z4)
DriveTrain:
  • S54 (126k miles) with new VAC motorsport coated bearings installed
  • E46 M3 cluster coded for 4 doors and corrected mileage
  • 6 speed Getrag Transmission
  • 3.62 M3 LSD w/ axles and complete rear end
Exhaust:
  • S54 Stock header
  • S54 midpipe with Jones Universal Maxflow Muffler in place of midpipe
  • Custom 3rd Rear section with Quad exhaust w/ aftermarket CSL diffuser for MtechII bumper
Suspension and Brakes:
  • E46 M3 Brakes front and rear
  • E46 M3 Coilovers (DGR Adjustable Coilover Suspension)
  • AKG Bushings: Spherical RTAB, Front Control Arm Bushing, Differential , Engine Mounts
  • Turner Motorsport front and rear swaybars
  • ZHP Steering Rack retained
  • E46 M3 lower FCA
  • E46 M3 Rear trailing arms
Wheels:
  • 19 inch E46 M3 Style 67 with 15mm spacer front
Options on Car:
  • Bixenon with FX-R retrofit
  • Natural Brown Leather interior refinished
  • Black Cube Trim
  • OEM Rear Electric Sunshade
  • OEM Park Distance Control
  • E46 M3 Power Electric Folding Mirror retrofit
  • E46 OEM Alarm
  • OEM Automatic Rain/Light Sensor retrofit
  • OEM Auto Dim Homelink Mirror retrofit
  • OEm E46 Rolling Code Homelink
  • OEM TPMS retrofit
  • OEM BMW RoofRack
  • ///M Track Mode DSC System retrofit
since my car is an MS45 car, the wiring was very minimal.
we pinted out WDS PINOUTs fro MSS54 for a 2002 MSS54 NON SMG and compared it to MS45 DME pinouts and made my harness pinouts match what ever the MS54 needed. depinned and moved pins where they needed to go.
EWS was coded out by a local software tuner as well as secondary pump under the hood for emissions. we used the S54 Fuel pump, lines and FPR/Filter setup as well. Retained the stock 330i relay and made sure to use Euro Fuel pump relay pin on S54 DME and it works just fine. Retained M54 AC compressor and changed to a different belt we got from autozone. installed M3 aux fan and airbox as well.
Love the quad exhaust, sounds very good and not too much rasp.
Pictures of starting, progress and complete are below and a video as well.
When it arrived on a truck October 2016 from Supreme Auto imports in Florida
IMG_20161018_225139-01 by Shawn Robertson, on Flickr
IMG_20161018_230609-01 by Shawn Robertson, on Flickr
Parts car purchased november
IMG_20161116_204238_01 by Shawn Robertson, on Flickr
IMG_20161116_204236_01 by Shawn Robertson, on Flickr
IMG_20161116_204211_01 by Shawn Robertson, on Flickr
Swap stuff getting ready
IMG_20170221_174449 by Shawn Robertson, on Flickr
IMG_20170221_174603 by Shawn Robertson, on Flickr
IMG_20170221_174651 by Shawn Robertson, on Flickr
IMG_20170221_174504 by Shawn Robertson, on Flickr
IMG_20170221_174524 by Shawn Robertson, on Flickr
IMG_20170221_174541 by Shawn Robertson, on Flickr
IMG_20170221_174838 by Shawn Robertson, on Flickr
IMG_20170223_181905 by Shawn Robertson, on Flickr
IMG_20170223_181925 by Shawn Robertson, on Flickr
IMG_20170223_185901 by Shawn Robertson, on Flickr
IMG_20170223_184011 by Shawn Robertson, on Flickr
IMG_20170228_175910 by Shawn Robertson, on Flickr
IMG_20170228_175929 by Shawn Robertson, on Flickr
IMG_20170228_175800 by Shawn Robertson, on Flickr
IMG_20170228_175630 by Shawn Robertson, on Flickr
IMG_20170228_180132 by Shawn Robertson, on Flickr
IMG_20170306_183624 by Shawn Robertson, on Flickr
IMG_20170306_181222 by Shawn Robertson, on Flickr
IMG_20170306_181150 by Shawn Robertson, on Flickr
IMG_20170307_191917-01 by Shawn Robertson, on Flickr
IMG_20170307_193104-01 by Shawn Robertson, on Flickr
nextelbuddy is offline   Reply With Quote
Old 06-09-2017, 12:47 PM   #2
nextelbuddy
My Ride: E36 M3
M3 on left, ZHP on right.
IMG_20170307_192953-01 by Shawn Robertson, on Flickr
IMG_20170307_190455-01 by Shawn Robertson, on Flickr
IMG_20170307_190404-01 by Shawn Robertson, on Flickr
IMG_20170313_182224-01 by Shawn Robertson, on Flickr
2017-03-14_09-27-15 by Shawn Robertson, on Flickr
IMG_20170320_180643 by Shawn Robertson, on Flickr
IMG_20170320_180446 by Shawn Robertson, on Flickr
IMG_20170320_180455 by Shawn Robertson, on Flickr
IMG_20170320_192733 by Shawn Robertson, on Flickr
IMG_20170320_190807 by Shawn Robertson, on Flickr
IMG_20170320_190751 by Shawn Robertson, on Flickr
IMG_20170411_182118-01 by Shawn Robertson, on Flickr
IMG_20170411_182103-01 by Shawn Robertson, on Flickr
This piece is the passenger side, it runs under the bumper re bar and will connect to ONE bank of the mid pipe, the driver side will just directly output to the 2nd bank of the mid pipe.
IMG_20170412_185725 by Shawn Robertson, on Flickr
IMG_20170412_215455772-01 by Shawn Robertson, on Flickr
IMG_20170425_210543 by Shawn Robertson, on Flickr
IMG_20170425_210507 by Shawn Robertson, on Flickr
IMG_20170426_145016 by Shawn Robertson, on Flickr
IMG_20170425_211614 by Shawn Robertson, on Flickr
IMG_20170424_193241 by Shawn Robertson, on Flickr
IMG_20170429_225356-01 by Shawn Robertson, on Flickr
IMG_20170429_234750-01 by Shawn Robertson, on Flickr
Under Carriage S54 ZHP by Shawn Robertson, on Flickr
2017-05-02 07.29.15 1 by Shawn Robertson, on Flickr
2017-05-02 09.54.50 1 by Shawn Robertson, on Flickr
2017-05-02 09.54.51 1 by Shawn Robertson, on Flickr
2017-05-02 09.53.51 1 by Shawn Robertson, on Flickr
2017-05-02 09.53.53 1 by Shawn Robertson, on Flickr
2017-05-02 09.53.52 1 by Shawn Robertson, on Flickr
2017-05-02 09.53.49 1 by Shawn Robertson, on Flickr
2017-05-02 09.53.50 1 by Shawn Robertson, on Flickr
Old 06-09-2017, 12:47 PM   #3
nextelbuddy
My Ride: E36 M3
Pics of the car as it sits today
IMG_20170512_033245 by Shawn Robertson, on Flickr
2017-05-09_0010 by Shawn Robertson, on Flickr
2017-05-09_0001 by Shawn Robertson, on Flickr
2017-05-09_0002 by Shawn Robertson, on Flickr
2017-05-09_0003 by Shawn Robertson, on Flickr
2017-05-09_0004 by Shawn Robertson, on Flickr
2017-05-09_0005 by Shawn Robertson, on Flickr
2017-05-09_0006 by Shawn Robertson, on Flickr
2017-05-09_0007 by Shawn Robertson, on Flickr
2017-05-09_0008 by Shawn Robertson, on Flickr
2017-05-09_0009 by Shawn Robertson, on Flickr
2017-05-30_0005 by Shawn Robertson, on Flickr
2017-05-30_0001-01 by Shawn Robertson, on Flickr
Video to hear the exhaust under full throttle and load.
Sponsored Links
Advertisement
Old 06-09-2017, 01:45 PM   #4
1stWorldProblems
My Ride: 04 330i, 05 S2000
beautiful
2004 330i ZHP
2005 S2000
2017 VW GTI
1stWorldProblems is offline   Reply With Quote
Old 06-10-2017, 03:26 PM   #5
hpeck83
My Ride: 2000 328i
Amazing job. If my swap turns out half as nice as yours did, I'll be happy.
Eh, It'll Buff
hpeck83 is offline   Reply With Quote
Old 06-19-2017, 02:07 AM   #6
youinreverse
My Ride: 2000 328i
Nice work. I'm doing this swap as well right now. I can't wait until it's finished.
youinreverse is offline   Reply With Quote
Old 06-19-2017, 02:34 AM   #7
Mflara20
My Ride: 04 330i
We should get together one day. I live in gwinnett as well and planning to do the same on my 05 330i.
Sent from my Pixel using Tapatalk
Mflara20 is offline   Reply With Quote
Old 07-26-2017, 01:21 AM   #8
YoitsTmac
My Ride: 328Ci
Saw this on ZHP mafia while it was a WIP. Great thread! Also saw you butt in on Kalim - so you didn't/can't use the ZHP transmission on S54?
YoitsTmac is offline   Reply With Quote
Old 07-27-2017, 10:50 AM   #9
derek502
My Ride: 2004 330ZHP
what are your plans for the M54 that you removed? I am looking for one for my 2004 ZHP
04 330 ZHP coupe
06 530i-wife's car
02 Dodge Dakota QC-4.7 with some mods
06 Dodge Ram 3500 Cummings
derek502 is offline   Reply With Quote
Old 07-27-2017, 03:55 PM   #10
pb_e46
My Ride: 2004 BMW ///M3
Damn son. You made that look so easy! Would love a S54 swapped wagon or ZHP sedan someday.
pb_e46 is offline   Reply With Quote
Old 07-28-2017, 07:52 PM   #11
18rabbit
My Ride: '02 330it
I'm curious to hear what an educated someone has to say about the quad exhaust. One bank now has about 2 ft of additional back pressure on it. Will that cause any issue? Car looks so sick BTW.
18rabbit is offline   Reply With Quote
Old 07-28-2017, 09:40 PM   #12
wildirish317
My Ride: 2004 325Ci vert
When you say "2 ft", are you talking about the length of pipe? That is minimal compared with the restriction in flow from the pipe to the exhaust tips. If you were racing this car, and $1,000s of dollars were on the line, yeah, it's worth smoothing out and evening out the pressure losses in the exhaust trains. But this is not the case, is it?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller - BIMMER
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 07-31-2017, 11:28 PM   #13
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Has my approval. Everything should just go fairly bolt in. The part that would annoy me is the electrical
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 08-16-2017, 01:31 AM   #14
nextelbuddy
My Ride: E36 M3
Thanks! What do you mean that I butt in on Kalim?
Yes you can use the ZHP 6 speed transmission on us 54 you just have to make sure to use the ZF 6-speed transmission matching flywheel and clutch. Does the S60 transmission uses a flywheel with the flywheel mounted pilot bearing whereas the gettrag transmission easy the standard pilot bearing mounted in the crankshaft.
I originally did plan on using my 60 transmission because I just bought an engine and no transmission but then after that I found a really good deal on a complete Parts car that had everything so I sold my s54 long block and my M54 swap and just kept s54 everything from my parts car.
I ended up selling my complete M54 6 speed swap to somebody local for around $1,800.
Old 08-16-2017, 01:06 PM   #15
YoitsTmac
My Ride: 328Ci
Sorry it sounded a little disrespectful the way I worded it. I just meant I saw you asking questions on his thread, particularly on this topic! I do have to ask if you don't mind. So you'd use the ZHP trans clutch/flywheel setup? And put the pilot bearing in the engine? I've been kind of holding off my ZHP tranny swap thinking I'd have incompatibility here down the road when I'm ready to do an S54 swap.
Old 08-21-2017, 08:01 AM   #16
nextelbuddy
My Ride: E36 M3
no worries!
if you keep your ZF 6 speed transmission and just swap in an S54 engine all you have to do is reuse flywheel from the M54 engine because it has a pilot bearing mounted inside the flywheel which the ZF tranny needs and then you have to use a clutch/pP combo for M54 as well to work with the flywheel. it will all bolt on with no issues to the S54.
Old 08-22-2017, 06:53 AM   #17
YoitsTmac
My Ride: 328Ci
no worries!
This is all information that was rather blurry until now. Sadly, I just got my hands on a Z4M transmission instead which uses the same clutch/flywheel's as the M3. Hopefully someone else will find that info useful!
Old 11-18-2017, 01:43 AM   #18
EclipsedEvo
My Ride: 04 330i ZHP, e92 M3
Send a message via AIM to EclipsedEvo
Looks great and loved the progress pictures
04 330i ZHP
GruppeM intake | Supersprint full exhaust | Shark Injector | UUC EVO3 SSK | UUC DSSR | 3.46 differential | 18x8.5 BBS RS-GT | Michelin PS | Koni FSD | M3 strut bar | TMS sway bars | R1 cross drilled rotors | Stoptech front pads | Posi-Quiet rear pads | ACS roof spoiler | perforated steering wheel | 35% 3M tint | Pioneer AVIC-X940BT | V1
EclipsedEvo is offline   Reply With Quote
Old 11-18-2017, 09:34 AM   #19
Mflara20
My Ride: 04 330i
We need to get together whenever I'm ready to swap mine. I'm sure I can bolt everything but the electrical part really what confuses me. If you have a schematic of what pin goes where that'll be awesome!
