Freaking valve cover washer seals... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-18-2017, 10:56 PM   #1
WilloCO
My Ride: '05 330xi 6 speed
After parking on an incline, I headed home and had some oil smoke. Crawled around and found oil all over my trans and burnt on my headers.
I found signs of oil on the back of the valve cover and thought one seal looked a bit loose.
Every single bolt on the valve cover was loose. The seals got soft when they warmed up and allowed things to loosen up.
I used some aftermarket seals I had on hand. I will use BMW washer seals and maybe some threadlock going forward.
Sigh, it was getting pretty clean under there.
Sent from my Nexus 5X using E46Fanatics mobile app
Originally Posted by YoitsTmac View Post
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Old 06-19-2017, 02:31 AM   #2
Pro325ie46
My Ride: 2004 BMW E46 325xi
Huh? So you forgot to tighten all of them when you did your valve cover gasket or what haha!
Pro325ie46 is offline   Reply With Quote
Old 06-19-2017, 06:07 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
No Loctite needed.
The normal way the valve cover is installed is to have the grommets distort and provide the clamp load for the valve cover. The valve cover bolts/nuts are tightened in a pattern about 4-6 times a small amount each time until the valve cover bolts/nuts actually bottom out. They are then tightened only a small bit more until the bolts/nuts are snug.
Whether OEM or aftermarket grommets the valve cover bolts/nuts will be bottomed out and torqued or snugged just a small amount.
You clearly did not have tighten the valve cover bolts/nuts to the point they bottomed out.
Old 06-19-2017, 09:07 AM   #4
WilloCO
I followed the torque rating, but achieved it without bottoming out the bolts.
I'm going to tighten them up before heading to work this morning.
I will probably re-do my entire VCG and seals in a week or so to be safe.
05 330xi 6 speed
Old 06-19-2017, 10:33 AM   #5
Starvega
My Ride: 323i
Torque ratings are dumb. Do it by feel, you'll know when to stop.
Starvega is offline   Reply With Quote
