Dipstick gurgling noise when car is running? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-16-2017, 06:00 PM   #1
B694515
My Ride: 325i
When I was changing my oil filter housing gasket I knew I would be adding up to a quart of oil. So after the repair I was checking the oil level and I noticed that even after filling the oil completely, when the engine was running and I was checking the dipstick, I was getting a gurgling or gasping sound.
Is that normal? Is it a CCV-related problem?
B694515 is offline   Reply With Quote
Old 07-16-2017, 06:24 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Leave the dipstick alone on a running engine.
You only remove the dipstick after the engine has been shut down.
There is a reason the dipstick has 2 O-rings on the base of the handle.
Old 07-16-2017, 06:30 PM   #3
B694515
My Ride: 325i
So no reason to change my CCV now? I was thinking something was going wrong.
Old 07-16-2017, 06:40 PM   #4
All2kool
My Ride: 2002 325Ci
And after 10-15 years, they become hard, shrink, and no longer do as they are designed. Spending $5.75 on preventative maintenance isn't going to break you either.
All2kool is offline   Reply With Quote
Old 07-16-2017, 09:27 PM   #5
B694515
My Ride: 325i
Interesting, I will pick those up. I was looking for those but all I could find is the lower dipstick o-ring.
Old 07-18-2017, 03:21 PM   #6
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
obviously they don't know what's involved to install that $5.75
and there is only one o-ring on mine
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
