Brake piston popped out of caliper - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-16-2017, 07:40 PM   #1
colefweber
My Ride: 2004 325i
Stopped working on left front brake because I also needed to do the wheel bearing. Had the rotor and caliper off, then moved to right side. Replaced rotors and pads on that side, then pressed on the brake pedal to test it. I didn't understand why the pedal felt squishy and went to the floor until there was a puddle of brake fluid under the drivers side front. Cleaned it up, replaced the wheel bearing, then tried to replace pads. The piston popped out with the pad (along with a TON of brake fluid) and refuses to go back in. What do I do?
colefweber is offline   Reply With Quote
Old 07-16-2017, 07:51 PM   #2
03325
My Ride: 03 325I
03325 is offline   Reply With Quote
Old 07-16-2017, 07:53 PM   #3
colefweber
My Ride: 2004 325i
Won't even go in with a c clamp. Don't I need to replace the gaskets?
Old 07-16-2017, 08:08 PM   #4
03325
My Ride: 03 325I
O rings? Is the Piston smooth you may have to polish with some 600 or so wetsand to knock off any corrosion. You can rebuild it now since it's out. The bleed screw is loose
Old 07-16-2017, 08:16 PM   #5
colefweber
My Ride: 2004 325i
Yeah o rings. Should I replace all that or do you think I'm fine rebuilding it with what I have?
Old 07-16-2017, 09:07 PM   #6
LeverThis
My Ride: 2004 325i automatic
Since you have it all out ....
You've done 95% of the work already, why not do the seals? Also, the car is pushing 13 years old and the seals could go sooner rather than later.
LeverThis is offline   Reply With Quote
Old 07-16-2017, 09:52 PM   #7
colefweber
My Ride: 2004 325i
True, thanks for the help!
