hazard lights and door lock button not working after air bag recall work - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-17-2017, 10:11 AM   #1
clydesdale
My Ride: e30, 2004 zhp
My wife brought car in for air bag and it left without hazards and door lock button working. I know the door lock button worked this morning before the work. Is this related? Do they have to disconnect anything that would effect these two buttons? Thanks.
clydesdale is offline   Reply With Quote
Old 07-17-2017, 04:46 PM   #2
seattle86
My Ride: '03 330 Ci
The airbag module is below the center console. Maybe they had to inspect it for some reason and didn't reconnect the connector on the back of the hazard/lock switch? It's easy enough to pry up the switch to check. Should come out with just your fingernails.
seattle86 is offline   Reply With Quote
Old 07-18-2017, 01:11 PM   #3
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Funny, the same exact thing happened when I got my airbag recall done. I figured it was a coincidence. The switch was plugged in, just not working. I seriously doubt this switch is removed when performing either of the airbag recalls.
I replaced it with a new switch and all was good again.
Old 07-18-2017, 01:11 PM   #4
LeMansteve
Old 07-18-2017, 01:55 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
The guts blow out the back of the center console switch, this is very common. It is possible that someone put the Hazards on or use the center console switch and it failed.
The switch is like $35, but you can often glue the rear back on the switch and save a few $$.
Old 07-18-2017, 04:02 PM   #6
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Yup. Most likely the back of the switch broken. There is a Chinese aftermarket version of the lock/hazard button assembly on eBay for under $11 total with shipping. Most are coming out of China, but, there are some US based seller. eBay ID "flygoodly" has it for $10.77 total from Humble, Texas.
I got one a while back just to check it out and the quality is more than decent. I was pleasantly surprised.
scottjoh is offline   Reply With Quote
Old 07-19-2017, 08:50 AM   #7
markusmarkus
My Ride: 2001 330Ci
Gorilla glue works perfectly to "restore" functionality to the switches.
