rear hatch button stopped working - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 10-01-2017, 04:59 PM   #1
jimpomm
My Ride: 01 330xi
I have a 2000 touring with 337k on it, still runs and drives fine. All of a sudden , my rear hatch button does not work, no click like usual, nothing. I know the trick of opening the hatch from the inside, but it's a pain, as I use this touring as my work truck. With that many miles , not too worried about hauling all kinds of things in the rear. Any ideas on how to troubleshoot and or test the switch. I have watched a couple utube vids on the switch when located on a sedan . Also is there a fuse to check?
jimpomm is offline   Reply With Quote
Old 10-01-2017, 06:07 PM   #2
yjsaabman
My Ride: '03 325i Touring
I'd be checking the wiring between the hatch and the body of the car. I fixed the rear defroster on my last one by locating a broken wire in the hatch jamb. It's fairly common to find broken wires in there, especially with the mileage on yours. Open the hatch and work one end of each boot free (there's wiring on the left and right sides) and pull it back and inspect things for breaks. You may also find some with cracked insulation that are getting close to breaking.
Sent from my SAMSUNG-SM-G930A using Tapatalk
yjsaabman is offline   Reply With Quote
Old 10-02-2017, 05:09 PM   #3
jimpomm
My Ride: 01 330xi
hmm, think you might have pointed me in right direction, I wiggled the wires you mentioned and the hatch latch is working again, I know that I need to open things up and repair the wire, ty.
Sponsored Links
Advertisement
Old 10-02-2017, 06:04 PM   #4
Onizukachan
My Ride: `04 M56 Touring
Please buy good friction tape. That area under the covers is exposed to water.
If I were to give my Touring a first name, I'd probably name it "Alan".
Mostly because I like puns.
DIY: E46 Touring TV Tuner Install/Mounting
DIY: Wiring City Lights, Rear Fogs, and Rear Camera in a Touring
Onizukachan is offline   Reply With Quote
Old 10-02-2017, 07:54 PM   #5
yjsaabman
Agreed. If the insulation is just cracked, but the wire itself is in good shape it's ok to just tape it up with some good quality tape. On the broken wires I solder and heat shrink to ensure a solid, lasting repair.
Old 10-07-2017, 10:49 PM   #6
mjez
My Ride: bmw
My in-law had a similar problem in his x3, ended up replacing the switch above license plate.
Sent from my Nexus 6 using Tapatalk
mjez is offline   Reply With Quote
