How I solved my DSC / Brake light problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-14-2017, 05:23 AM   #1
LtDkAngel
My Ride: S3 316i Compact
I have a s3 316i compact E46 and a few days ago I was on a road that I did not know too well and I hit really big bump on it and after that I got the dsc and handbrake light in yellow stuck , meaning they never go away when the engine is on ! I put the car on a tester to see what codes I get and well I got camshaft sensor and oil temperature sensor! I change the camshaft sensor twice with no change so I presume that's because of some fault on the wiring being that my car was leaking oil and that the cable was always covered in oil anyway I had that error from when I got the car and well the car works just fine even with that error ! I change the oil temperature sensor and no I don't get any other error code other then the camshaft one ! Light's still did not go out , I have brake fluid cause I checked , I change the gaskets were it was leaking oil and did a oil fill still the lights are on ! I know that when I got the car my handbrake was pretty much useless so I checked what the problem was there and fix it let's just say that I needed to change a few things thought that still did not fix the lights ! I checked to see if I have a fuse blown out but nop all are fine . So guys if any of you has an idea what the problem might be I'm waiting for suggestions cause right now I'm kind of lost
Ps: The picture is not from my car It's one that I found on the internet but I get exactly the same thing !
LtDkAngel is offline   Reply With Quote
Old 09-14-2017, 08:02 PM   #2
jmo69
My Ride: 03 325xi 98 328is
You need a scanner that reads more than OBDII codes.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 09-15-2017, 01:21 AM   #3
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
There are several threads on this site regarding this subject.
You need to get the oil leaking fixed, that's a leading cause of car fires, especially if it's coming off the passenger side.
Seems from memory one of the things that can cause this is the wheel speed sensors getting fouled up with debris. The codes you pull just point you in a general direction but sometimes they're a bit misleading.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
