P1343/ Misfire in cylinder 1 with fuel cut off - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-14-2017, 06:12 PM   #1
Kyledale4
My Ride: 03 BMW 325xi
This isnt the first time I've had this code pop up in the 2 years I've had my 03 325xi and the first time I narrowed the problem down to the coil, so I changed out all of them even though they may not have been faulty, and I also kept the OEM coils also, today I pulled the coil out and replaced it and cleared the codes and nothing changed, so I tried the other 5 OEM coils I had and still no change even with clearing the codes. So I went to O'rileys and bought a new spark plug hoping this would be the problem and nothing happened, this is the only code that shows up so I don't know what to go for next.
Kyledale4 is offline   Reply With Quote
Old 09-14-2017, 06:37 PM   #2
kbsilver
My Ride: 2000 328i
I had some similar (non coil related) misfires in our 540. In this case it was a bad connection (crimp?) at the fuel injector socket for that cylinder (apparently common enough the dealer knew what it was right away). The dealer spliced in a new socket for one cylinder. For the other I found if I just tugged on the wire to the socket, problem went away for a few years each time. May or may not be your issue.
kbsilver is offline   Reply With Quote
Old 09-14-2017, 07:43 PM   #3
Kyledale4
Originally Posted by kbsilver View Post
I had some similar (non coil related) misfires in our 540. In this case it was a bad connection (crimp?) at the fuel injector socket for that cylinder (apparently common enough the dealer knew what it was right away). The dealer spliced in a new socket for one cylinder. For the other I found if I just tugged on the wire to the socket, problem went away for a few years each time. May may not be your issue.
I looked for this and I didn't see any crimped or pinched wires anywhere
Sponsored Links
Advertisement
Old 09-14-2017, 08:21 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Most misfires are actually due to Lean problems.
I think you can rule out secondary ignition at this point.
Need to see Freeze Frame and warm idle Fuel Trim info. Also need to see the exact code in the Pxxxx format.
Is the misfire constant or does it clear when you restart the engine?
Old 09-14-2017, 08:39 PM   #5
Kyledale4
it's pretty clear when the engine starts it'll shake pretty bad and it sounds like it has a high roller cam in it. I can clear the code and it'll be right back on in about a minute and that'll be the only one that will pop up, so an O2 sensor isn't catching anything if it's running lean
Old 09-14-2017, 08:58 PM   #6
jfoj
Not sure this is the case, an O2 sensor can detect if there is a Lean problem, HOWEVER, on start up, cold or even partially cold the engine runs in Open Loop with cold start enrichment while the O2 sensors are coming online. Additionally if there is only a single misfire, the engine fuel management system can only adjust the fuel delivery by around 25% which may not be enough to mask a Lean condition and this is just masking the problem, not correcting the problem.
So you need to provide some solid data to back up what is going on. Codes in the Pxxxx format, Freeze Frame and warm idle Fuel Trims.
Also suggest you read the first post in this thread at least 3 times: Solve your misfires, lean codes, rough idle - http://forum.e46fanatics.com/showthread.php?t=897616
Old 09-15-2017, 08:40 AM   #7
kbsilver
My Ride: 2000 328i
This is nothing you can see. What I am talking about is corrosion between the wire and the connector INSIDE the plug that connects to the fuel injector. Inside the plug the actual metal connector is crimped onto the wire.
Old 09-15-2017, 09:35 AM   #8
markusmarkus
My Ride: 2001 330Ci
OP, listen to what jfoj is saying. He knows his stuph!
