Probably bricked - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-25-2017, 07:16 PM   #1
Amerced
My Ride: 2002 325i
Probably bricked
Was using jmgarageflasher to read my dme and it kept freezing at random percentages, and giving "wrong echo bytes" when trying to connect, eventually got it to connect, then was getting "wrong echo answer" as i said at random percentages, between tries id wait a few minutes to see if the processes would complete, never moved, eventually i gave up and plugged everything back in, now my car cranks but doesn't start
ID:	683929   Click image for larger version
ID:	683937   Click image for larger version
Amerced is offline   Reply With Quote
Old 09-25-2017, 09:10 PM   #2
armenh7
My Ride: 2002 325i
I'm assuming you were using jmgarage flasher on a bench?
When I tried using it to read the 512kb from my DME on a bench, I would always get wrong echo bytes after successfully connecting. I downloaded the older version and it worked perfectly fine.
I suggest using galletto to see if you can still read the ecu data or the 64kb bin. Also, if you have inpa, connect to the DME and see if it'll connect successfully.
armenh7 is online now   Reply With Quote
Old 09-25-2017, 09:14 PM   #3
Amerced
My Ride: 2002 325i
Using it in car, can't get galletto to work with my cable and I'll be checking with inpa tomorrow, if it does connect could i just go about maybe using a different computer with xp, I'm running Windows 10, and still just flash the bin for the 3.0 since the whole reason I'm doing this is i did the 3.0 swap
Sponsored Links
Advertisement
Old 09-25-2017, 09:15 PM   #4
armenh7
My Ride: 2002 325i
By "can't get galletto to work with my cable" have you set it up properly? Meaning changing the serial number in galletto.
Old 09-25-2017, 09:30 PM   #5
Amerced
My Ride: 2002 325i
Mprog won't read and parse, throws an error
Old 09-25-2017, 09:30 PM   #6
armenh7
My Ride: 2002 325i
Have you tried redownloading it?
Old 09-25-2017, 09:39 PM   #7
Amerced
My Ride: 2002 325i
Ya i redownloaded all of the programs today and then these pictures were as far as i was able to get
Old 09-25-2017, 09:42 PM   #8
armenh7
My Ride: 2002 325i
What error does it specifically throw?
Old 09-25-2017, 09:47 PM   #9
Amerced
My Ride: 2002 325i
Error read eeprom failed device but it pulls it up when i scanfor it as a programmed device
Old 09-25-2017, 09:48 PM   #10
armenh7
My Ride: 2002 325i
May I please see a picture? And what drivers do you have installed for your cable?
Old 09-25-2017, 09:49 PM   #11
Amerced
My Ride: 2002 325i
Failed device 0
Old 09-25-2017, 09:49 PM   #12
Amerced
My Ride: 2002 325i
Ya let me get that
Old 09-25-2017, 09:59 PM   #13
Amerced
My Ride: 2002 325i
This is what i got
ID:	683953   Click image for larger version
Old 09-25-2017, 10:04 PM   #14
armenh7
My Ride: 2002 325i
This is what i got
Okay so uninstall the driver you currently have and install this driver.
https://mega.nz/#!XpVyURrT!R0iptDfwa...nMXd3uESwQzn2Q. Just unzip the file and open "CDM20828_Setup.exe".
Old 09-25-2017, 10:43 PM   #15
Amerced
My Ride: 2002 325i
still the same unfortunately
Old 09-25-2017, 10:45 PM   #16
armenh7
My Ride: 2002 325i
Hmm if it gives an eeprom error, that would suggest something is wrong with your cable. Are you able to use inpa to access the DME and other modules?
Old 09-25-2017, 10:49 PM   #17
Amerced
My Ride: 2002 325i
just dme
Old 09-25-2017, 10:50 PM   #18
armenh7
My Ride: 2002 325i
just dme
Just to clarify, you are able to connect to your DME with inpa?
Old 09-25-2017, 10:51 PM   #19
Amerced
My Ride: 2002 325i
yes I was prior to this issue, haven't checked after the no start
Old 09-25-2017, 10:52 PM   #20
armenh7
My Ride: 2002 325i
Okay then your cable is fine. Maybe try using a different port on your computer when using Mprog. Also try running mprog in compatibility mode.
dme brick ms43
