Issues starting my M3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-01-2017, 03:48 AM   #1
jmruvira
My Ride: E46-M3
Hello y'all, I'm trying to seek a little help form this forums experienced mechanics hopefully. My E46 M3 was not started for a while and the tank was left totally empty. Today I put in it 5 gallons of fresh premium gas and I tried to start it but it wont start up. It turns over just fine but wont turn on. Does anyone have any idea what it could be or how to diagnose it?
Thank you all any and all help will be greatly appreciated. I've gone through hell with this car trying to get it back road worthy, from body shop lying about painting my car to mechanics skimming me. Since I'm not big on confrontations I just let people screw me over and move on, sorry for venting here but I just had to do it.
jmruvira is offline   Reply With Quote
Old 10-01-2017, 08:39 AM   #2
markusmarkus
My Ride: 2001 330Ci
It takes a bit of time for fuel to get from the pump in the tank to the engine when the tank is empty. Are you sure the fuel pump is running? Check the fuse. Also, turn the ignition switch to the run position without goi g to the start position. Can you hear the fuel pump priming? Remove the back seat cushion to hear the fuel pump better.
Old 10-01-2017, 07:07 PM   #3
doukas007
My Ride: e46 facelift coupe
Well, you should start from the basics which would be:
Battery
You said that car was sitting for some time due to work so maybe battery is out of juice. Jack it up on a professional charger and try again, or jump start the car (if you jump start it and the battery is actually empty, chances are that the next time you try to start it it will die egain, it takes a long trip to fully charge a battery from the car itself
Fuel pump
As suggested before, you should start by priming the pump by turning the key on accessories position waiting one or two seconds and then turning it all the way... Also, you may have a soft failing pump that is not circulating enough fuel when fuel level is low (if an e46 m3 pump is like a normal e46 in which this is quite common)
If these dont help , you should try to find a comprehensive gude post tha examines every possible no start cause :
http://forum.e46fanatics.com/showthread.php?t=1011677
Sent from my kidnapper
doukas007 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-02-2017, 01:54 AM   #4
jmruvira
My Ride: E46-M3
Guys thx a million, I followed y'alls instructions and I found the culprit a fuel pump gone bad. When I removed the back seat and set my key to the accessories position and there was zero noise coming from the pump priming itself, I immediately suspected that. I checked the voltage and fine 12v. Then I removed it and WOW HOLY COW the sock filter was in pieces, the little hoses that get stuck when u try to remove the assembly were cracked in half, the rubber seal was like paste in your hand melting off, the float was also falling apart. I mean this was a nightmare never leave a car with a totally empty tank, I think is what did it in Miami's super hot ass climate.
So I guess my first project would be to clean the inside of the tank as best as I can, correct fellas? Then purchase a fuel pump and assembly, unless do you guys know if the fuel assembly parts can be purchased separately?
Old 10-02-2017, 02:00 AM   #5
jmruvira
My Ride: E46-M3
THX doukas007 and markusmarkus, I posted an update..
Old 10-02-2017, 11:54 AM   #6
doukas007
Buy an oem fuel pump, the whole assembly, I don't know if there are spares but it doesn't worth it anyway, as for the tank I guess you could try to clean it but I doubt it will be very effective cause you can't really get your hands everywhere
Old 10-02-2017, 12:33 PM   #7
Jagdtiger
My Ride: 05 330CI
You can buy just the pump but I would go ahead and replace the whole assembly. Get a vdo and you should be good.
Jagdtiger is offline   Reply With Quote
Old 10-02-2017, 07:21 PM   #8
jmruvira
My Ride: E46-M3
Yea that makes sense. I was just hopping I could change the couple of parts that were broken on it, as a new one will cost like $400. I could buy a used assembly but I still will need the pump so I would be around $500 and that's what I was trying to avoid, but hey its European nothing is cheap on them, lol...
Old 10-02-2017, 08:08 PM   #9
jfoj
My Ride: 330CiC, M5, X5, E93
The BMW Part Store show the pump assembly, 16142229684 @ $364.25
https://thebmwminipartstore.com/
Old 10-03-2017, 08:59 AM   #10
markusmarkus
My Ride: 2001 330Ci
And the bmwminipartstore is a dealer so you know you’re buying quality.
Old 10-03-2017, 09:53 AM   #11
fordy_4
My Ride: 2000 BMW 330ci
Yes go OEM. Don't forget the sealing gasket too, and if it's your first time doing it then watch a few DIY videos on how the seat the gasket properly. I didn't and had fuel leaks in my 330 as a result. Lesson learnt.
My first BMW ---
2000 BMW E46 330ci
Fern Green Division
16:9 On-Board Monitor | Rear PDC | Xenons | ZSP | Sunroof | Golf tee mod | Michelin PS4
Question about belts & pulleys?
https://www.fcpeuro.com/blog/posts/m...elts-explained
fordy_4 is offline   Reply With Quote
Old 10-03-2017, 11:41 AM   #12
jmo69
My Ride: 03 325xi 98 328is
Mount the seal to the tank and then the pump, followed by the ring.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
fuel not reaching engine, m3 not turning on, not running, wont run, wont start
