HVAC IHKA blower fan always comes on with ignition - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-05-2017, 02:34 PM   #1
Canadian330ci
My Ride: 2001 330ci
I've researched this until I went crosseyed and even learned how to do some basic coding with NCSExpert yet I can't find a way to keep the darned blower fan from coming on with ignition. The climate control unit (IHKA) remembers every last buton and setting before I turn it off, but brings the fan speed to minimum when ignition is back on. I even tried using the memory seat buttons and no use. It's a 2001 330ci with the auto climate control unit. There's a PDF from BMW about customization per key that clearly states you can have the automatic blower fan speed on with ignition or off.
The very last option at the end of this document says this is possible
https://www.dropbox.com/s/svkz0fju4p...tions.pdf?dl=0
Here's the coding options I pulled with NCSExpert..and turned almost all on or off with no luck. Any ideas? THANKS for any input or suggestions
MIN_WT_SOLLWERT
nicht_aktiv
HECKSCHEIBE_HEIZZEIT
verlaengert
UEBERLAUFSTEPS_BEI_100%
nicht_aktiv
TAKTUNG_HHS
aktiv
UEBERLAUFSCHRITTE_BEI_0
nicht_aktiv
DISPLAY
anzeige_32_grad
AUTO_LED_GEBL_MANUELL
nicht_aktiv
AUTO_LED/SCHRIFTZUG
nicht_aktiv
KENNFELDKUEHLUNG
nicht_aktiv
KLIMATASTE_SPERREN
nicht_aktiv
LDA_BEI_VERBRAUCHER
nicht_aktiv
LDA_BEI_UNTERSPANNUNG
nicht_aktiv
DISPLAYANZEIGE_HIGH
aktiv
DISPLAYANZEIGE_LOW
aktiv
KENNLINIE_WAERMETAUSCHER
nicht_aktiv
DISPLAY_GEBLAESRAHMEN
nicht_aktiv
AUSSENTEMP_ABH_GEBL_ANH_1
nicht_aktiv
AUSSENTEMP_ABH_GEBL_ANH_2
nicht_aktiv
AUSSENTEMP_ABH_GEBL_ANH_3
nicht_aktiv
AUSSENTEMP_ABH_GEBL_ANH_4
nicht_aktiv
LUFTVER_AUT_B_ZUEND_EIN_1
nicht_aktiv
TAKTEN_HIGH_LOW_ANZEIGE_1
nicht_aktiv
LUFTVER_AUT_B_ZUEND_EIN_2
nicht_aktiv
TAKTEN_HIGH_LOW_ANZEIGE_2
nicht_aktiv
LUFTVER_AUT_B_ZUEND_EIN_3
nicht_aktiv
TAKTEN_HIGH_LOW_ANZEIGE_3
nicht_aktiv
LUFTVER_AUT_B_ZUEND_EIN_4
nicht_aktiv
TAKTEN_HIGH_LOW_ANZEIGE_4
nicht_aktiv
GEBLAESEKORREKTUR_1
nicht_aktiv
GEBLAESEBALKEN_AUT_MOD_1
nicht_aktiv
BELUEFTUNGSKLAPPE_OEFF_1
nicht_aktiv
KLAPPEN_OEFFNEN_1
nicht_aktiv
SOLLWERT_KORREKTUR_1
nicht_aktiv
KLIMABETR_BEI_ZUEND_EIN_1
nicht_aktiv
GEBL_AUT_B_ZUEND_EIN_1
nicht_aktiv
GEBLAESEKORREKTUR_2
nicht_aktiv
GEBLAESEBALKEN_AUT_MOD_2
nicht_aktiv
BELUEFTUNGSKLAPPE_OEFF_2
nicht_aktiv
KLAPPEN_OEFFNEN_2
nicht_aktiv
SOLLWERT_KORREKTUR_2
nicht_aktiv
KLIMABETR_BEI_ZUEND_EIN_2
nicht_aktiv
GEBL_AUT_B_ZUEND_EIN_2
nicht_aktiv
GEBLAESEKORREKTUR_3
nicht_aktiv
GEBLAESEBALKEN_AUT_MOD_3
nicht_aktiv
BELUEFTUNGSKLAPPE_OEFF_3
nicht_aktiv
KLAPPEN_OEFFNEN_3
nicht_aktiv
SOLLWERT_KORREKTUR_3
nicht_aktiv
KLIMABETR_BEI_ZUEND_EIN_3
nicht_aktiv
GEBL_AUT_B_ZUEND_EIN_3
nicht_aktiv
GEBLAESEKORREKTUR_4
nicht_aktiv
GEBLAESEBALKEN_AUT_MOD_4
nicht_aktiv
BELUEFTUNGSKLAPPE_OEFF_4
nicht_aktiv
KLAPPEN_OEFFNEN_4
nicht_aktiv
SOLLWERT_KORREKTUR_4
nicht_aktiv
KLIMABETR_BEI_ZUEND_EIN_4
nicht_aktiv
GEBL_AUT_B_ZUEND_EIN_4
nicht_aktiv
ZUHEIZER
konventionell
AUTOM_UMLUFT_CONTROL
nicht_aktiv
UMLUFT_MEMORY
aktiv
ZUHEIZ_RELAIS
nicht_aktiv
BORDMONITOR
nicht_aktiv
ZYLINDER_ZAHL
6_zylinder
MOTOR_ART
benziner
GEREGELTER_KOMPRESSOR
gross
SOLARSENSOR
nicht_aktiv
SOLARSENSOR_GEBL_BALKEN
nicht_aktiv
ZUSATZWASSERPUMPE
nicht_aktiv
EL_DURCHLAUFERHITZER
nicht_aktiv
FUSSRAUMKLAPPE_SCHLIES_1
nicht_aktiv
ENTFROSTKLAPPE_SCHLIES_1
nicht_aktiv
KENNLINIE_AUTO_GEBLAESE_1
nicht_aktiv
FUSSRAUMKLAPPE_SCHLIES_2
nicht_aktiv
ENTFROSTKLAPPE_SCHLIES_2
nicht_aktiv
KENNLINIE_AUTO_GEBLAESE_2
nicht_aktiv
FUSSRAUMKLAPPE_SCHLIES_3
nicht_aktiv
ENTFROSTKLAPPE_SCHLIES_3
nicht_aktiv
KENNLINIE_AUTO_GEBLAESE_3
nicht_aktiv
FUSSRAUMKLAPPE_SCHLIES_4
nicht_aktiv
ENTFROSTKLAPPE_SCHLIES_4
nicht_aktiv
KENNLINIE_AUTO_GEBLAESE_4
nicht_aktiv
EINSCHALTSCHW_AUTO_UMLUFT
wert_01
AUSSCHALTSCHW_AUTO_UMLUFT
wert_01
AUTO_UMLUFT_ZEIT
wert_01
TEMPERATUR_EINHEIT
grad_f
_a_
Canadian330ci is offline   Reply With Quote
