Old 04-17-2002, 09:45 AM   #1
sycE46
My Ride: 323ci
Installing CD changer... where do I get the power?
I'm going to put my Pionner CD changer in soon. Where do I tap into for power? Do I go straight to the battery? or is there anywhere else in the trunk where I can tap power? Also... what size fuse do I need?
thanks
sam
sycE46 is offline   Reply With Quote
Old 04-17-2002, 09:47 AM   #2
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
(+) can come right from a battery if you want...
you can ground (-) anywhere there is exposed metal.
You should check the CD-Changer manual to determine what size fuse you shoudl be using.
vinnymac is offline   Reply With Quote
Old 04-17-2002, 10:37 AM   #3
sycE46
My Ride: 323ci
I'm looking for the Positive voltage. Or does the power come from the BMWPILA adapter? The adapter should be arriving in the mail today. I want to make sure I have everything before I install.
I don't have the manuals for the cd changer anymore. I bought it over 4 years ago. The cd-changer is from my old car. Would I be okay with a 1 amp fuse?
Old 04-17-2002, 11:44 AM   #4
mfino
I give up.........
My Ride: 00 323i SP-P blk/blk
If you are using the Peripheral adapter and the changer is compatible, there is no need to run power, assuming you are using the factory pre wire. It's basically plug-n-play
ECIS Intake | Shark Injector | Scorpion Exhaust | PG2 style rims, YOKOHAMA AVS ES100 235/40/18 | M3 Lip Spoiler | OEM Clears | Hamann Eyelids | M-Technik Front | M-Technik Sides | M-Aero Rear | 50% Tint | M3 Dead Pedal | MOMO Aluminum Pedals | UUC Gauges |Titanium Shadow Painted Trim
mfino is offline   Reply With Quote
Old 04-17-2002, 01:57 PM   #5
vinnymac
My Ride: 2011 335is
Not sure about the adaptor...
but 1 amp fuse seems too small.
