Old 06-16-2002, 04:57 PM   #1
Hitman
My Ride: 323Ci Exec
Arrow How to remove the trim near front window?
Hi,
I'm not sure how it's called what I want to remove, but I'll try ro explain. I'm replacing a carkit but the microphone is placed on the drivers side left of the front window (where it says "airbag") and left of the visor. Is there a DIY manual somewhere on how to remove this? I think the wire runs underneath there to the radio.
TIA!
Hitman is offline   Reply With Quote
Old 06-19-2002, 02:10 AM   #2
Hitman
My Ride: 323Ci Exec
Sorry to kick this thread, but I really could use an answer to my question (read: I'm desperate). Does anybody know how to remove the fabric so I can remove the wires and put in a new microphone?)
(if nobody knows an answer I'll just rip it open I guess :sad:... j/k)
TIA!
Old 06-19-2002, 02:21 AM   #3
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
just rip it off
YOu have to pry gently. All those pieces bend but you have to be careful because that airbag is in that piece. I would start from the top near the roof if I was you. Just bend a little and a little more until you can see how it works. If you break the piece then no worries the panel is only 27 bucks. If you screw the airbag then you are out some dough. Just be careful. I would if I were you just get some professional help if you are feeling uneasy about it.
mcabr is offline   Reply With Quote
Old 06-19-2002, 04:42 PM   #4
Hitman
My Ride: 323Ci Exec
Re: just rip it off
Thanks for the info, just what I needed. I really had no idea where to start, but I'll be carefull and it should work out fine.
Thanks again!
Old 06-19-2002, 04:55 PM   #5
wkay
My Ride: 2002 330Ci
Re: How to remove the trim near front window?
Originally posted by Hitman
Hi,
TIA!
Hard to decide what you're referring to - headliner? A-pillar trim? Have you got a picture? Nothing on my car says Airbag. In both cases you need to pull up that inside trim piece that runs around the edge of the door openings, BMW calls it a mucket. If you get into the A-pillar where the airbag is located, disconnect the battery first and make sure the key is out of the ignition when you do it.
wkay is offline   Reply With Quote
Old 06-19-2002, 05:01 PM   #6
Hitman
My Ride: 323Ci Exec
Re: Re: How to remove the trim near front window?
I think what I mean is indeed called the A-pillar (just learned the term today ). The microphone is located near the ceiling on the top edge of the A-pillar. Thanks for the tip of removing the key when disconnecting the battery. Why isn't that in the manual?
Old 06-20-2002, 10:05 PM   #7
wkay
My Ride: 2002 330Ci
Try this:
Old 06-20-2002, 10:42 PM   #8
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
make sure your hands are clean so you don't stain it...
JetBlackE46 is offline   Reply With Quote
Old 06-21-2002, 02:54 AM   #9
Hitman
My Ride: 323Ci Exec
Excellent! Thanks for the manual wkay, where did you get this from? And indeed a good tip JetBlackE46, I'd probably kill myself if I left black fingerprints all over the light fabric.
Old 06-21-2002, 02:58 AM   #10
chrisbbb
My Ride: 99 328I
Send a message via ICQ to chrisbbb Send a message via AIM to chrisbbb
I would like to know where the manual pics came from as well. Please fill everyone in.............
chrisbbb is offline   Reply With Quote
Old 06-21-2002, 06:40 AM   #11
The Jake
My Ride: 2002 BMW 330CiC
I'm interested in the same info as it pertains to the convertible. We don't have that little strip that hides the screws. its one solid plastic piece.
Jake
The Jake is offline   Reply With Quote
Old 06-21-2002, 03:19 PM   #12
wkay
My Ride: 2002 330Ci
From the BMW service manual - TIS CDRom. Fyi, I had a fingerprint on my headliner, took it off with K2R. Headliner looks like new.
Old 06-21-2002, 03:30 PM   #13
wkay
My Ride: 2002 330Ci
Jake
Procedure for convertible-
Old 06-21-2002, 05:21 PM   #14
The Jake
wow. awesome thanks.
Old 06-21-2002, 09:20 PM   #15
luckster
My Ride: 2002 325i
wkay,
Those instructions are great! Where can you get a BMW service manual?? Is it on a Cd Rom? Would you be interested in sharing with the rest of us?
luckster is offline   Reply With Quote
Old 06-21-2002, 11:03 PM   #16
wkay
My Ride: 2002 330Ci
Originally posted by luckster
wkay,
BMW Service CDROM
