Old 04-17-2002, 11:36 AM   #1
jpetch
need $$$
My Ride: 2004 M3 SMG
where can i get clear front bumper reflectors?
i cant seem to find them anywhere.....
jpetch is offline   Reply With Quote
Old 04-17-2002, 11:36 AM   #2
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
I got mine here:
http://www.autodynamic.com
B is offline   Reply With Quote
Old 04-17-2002, 11:38 AM   #3
Daniel330ci
you can find it here.....www.procarparts.com
Daniel Lin
Daniel330ci is offline   Reply With Quote
Old 04-17-2002, 11:48 AM   #4
Jake N
Lord of the Idiots
My Ride: 323Ci
Send a message via AIM to Jake N
turner motorsports
Jake N is offline   Reply With Quote
Old 04-17-2002, 11:53 AM   #5
jpetch
need $$$
hey B
at autodynamics.com, was the $39.95 price for a set of 2?
Old 04-17-2002, 11:56 AM   #6
B
B's Avatar
Re: hey B
yep... $39.95 per car basically
Old 04-17-2002, 11:56 AM   #7
B
B's Avatar
Re: Re: hey B
Originally posted by B
yep... $39.95 for the left and the right
Old 04-17-2002, 11:57 AM   #8
jpetch
need $$$
one more thing, B...
are they easy to install? do i just pop them on?
Old 04-17-2002, 12:25 PM   #9
vernong
My Ride: Steel Gray 01 330ci
Send a message via AIM to vernong
clear bumper reflectors
I got mine from Bimmer Toys(Turner Motor Sports)they were junk, the right one went in with out any problems, the left one didn't come close to fitting so I had alot of filing to do to try and make it fit.finally it cracked and into the garbage they both went I still think they look great and I want to give it another shot at puting in a good pair.If I can fine a good pair.
vernong is offline   Reply With Quote
Old 04-17-2002, 12:32 PM   #10
B
B's Avatar
Mine were relatively easy to install. I followed the directions here:
Clear Reflector Installation
Have someone help you, even a girlfriend, and it's not hard at all. File the edges a bit if they're too big, and lube them a little. Then have one person push down to compress the spring-clip which holds them in securely, and the other person pushes them into the bumper.
Hope that helps!
B
Old 04-17-2002, 02:08 PM   #11
eddie@tirerack
Police Officer
My Ride: 03 Dodge Intrepid
Agreed.
I agree. I also picked mine up from Turners, (40.00), and found the left dropped right in ok, right side had to trim several times & was a MAJOR PITA.. I did see a DIY (bmw330ci.com?) that mentioned after the fact that the DIY experience also found trimming needed.. Small crack at the top of it was the result so barely noticable, but wondering if it was worth it...
..who am I kidding, of course it was- looks great with clears, just be forewarned they are a hassle!
eddie@tirerack is offline   Reply With Quote
Old 04-17-2002, 03:10 PM   #12
vernong
reflectors
Thanks Eddie,for awhile I thought it was only me that had the trouble with the JUNK
Old 04-17-2002, 03:11 PM   #13
B
B's Avatar
Maybe it's the ones from Turner only?!? Or maybe it's cause I'm better looking! :tongue:
Old 04-17-2002, 03:14 PM   #14
jpetch
need $$$
hey B
were the ones that you got from autodynamics.com okay for you? any problems with the installation?
Old 04-17-2002, 03:23 PM   #15
Daniel330ci
procarparts.com sells it for only 24.95..you may want to look at it
Daniel Lin
Old 04-17-2002, 03:33 PM   #16
jpetch
need $$$
hey daniel, i kind of wonder why it is so much cheaper at procarparts.com than all the other places. that makes me wonder if they are giving me a piece of crap light. what do you think?
Old 04-17-2002, 04:53 PM   #17
geduardo
My Ride: Steel Gray 325Ci
Send a message via AIM to geduardo
Talking clears
I bought mine from streetwize and cracked the first set....and the second set but I only cracked the very top of it, you can't even tell. They are a pain in the a$$ though. I had to file down both sides but it looks a lot better know. It was definitley worth it!!
geduardo is offline   Reply With Quote
