Old 04-17-2002, 12:42 PM   #1
NickACS
BOOM!
My Ride: TWC E46 ETCC WB
Need help from Hagus mirror *sedan* owners!
Hi everyone...I am still needing help to convince my bodyshop to fit the OEM motors in my '01 330i sedan Hagus mirrors. They said it is impossible/too hard to do. Has anyone with a sedan been able to do it and retain the mirror memory presets AFTER the motor swap was done?? Coupes apparently have it much easier and the swap is really simply. Darn sedans! :tongue: Thank you so much!
NickACS is offline   Reply With Quote
Old 04-17-2002, 12:45 PM   #2
sgv321
My Ride: 328
Re: Need help from Hagus mirror *sedan* owners!
me too.
sgv321 is offline   Reply With Quote
Old 04-17-2002, 12:50 PM   #3
joe330ci
My Ride: 330ci
actually, i've tried it on my coupe and wasn't successful. i was able to swap the motors out but couldn't stick the oem motor to fit into the hagus in the position it was in the oem housing. so mirror was slightly off and the tilt down function became a tilt "some other direction" function. in the end, i just kept the hagus motors in the hagus housing and lost my tilt down function. :sad:
joe330ci is offline   Reply With Quote
Old 04-17-2002, 01:49 PM   #4
NickACS
BOOM!
Well, I don't mind if I lose the "tilt-down" feature because I hate it anyways! I'm more wanting to get the mirror memory presets back...It is such a pain after I keep moving my seat around! hehe..
Old 04-17-2002, 03:11 PM   #5
GBX330ci
My Ride: 2011 Cayenne 6sp
Send a message via AIM to GBX330ci
Nick, Harrison told me the same thing for my coupe. Let me know if you figure it out
GBX330ci is offline   Reply With Quote
Old 04-17-2002, 03:44 PM   #6
KromeX
all stock
My Ride: stock 330i
I have the OEM motors inside the Hagus housing. The strange thing is that once you get them in, the motors are all upside-down so my driver's side mirror moves up when I adjust it inside the cabin and down when I move the joystick up and same thing for left and right. The passenger side is completely whacked. Left is up, down is right, up is right, down is left. This is because the motors is not exactly upside down but upside-down at a 45 degree angle and it's not resting on the Hagus mounting points. I had to fabricate a mounting point in between the mounting points on the Hagus housing in order for the OEM motor on the passenger side to fit. I do get full power options as well as memory options but I've lost the tilt-down in reverse.
KromeX is offline   Reply With Quote
Old 04-17-2002, 03:59 PM   #7
NickACS
BOOM!
KromeX, thanks for the info...You wouldn't by any chance have anymore writeup/DIY on exactly what you did? :smile: Just thinking I could take that to the bodyshop and have them work off of it. Do you think it is possible to get the motor totally upside down, instead of the 45 degree angle, or is it just not possible?
Thanks...
Old 04-17-2002, 04:05 PM   #8
KromeX
all stock
My Ride: stock 330i
Sorry, I don't have a write up. You can't get the motor completely upside down because you wouldn't be able to clip the mirror back onto the motor and have the mirror fit inside the housing. It's hard to explain but you'll get it if you try.
Old 04-17-2002, 04:09 PM   #9
NickACS
BOOM!
Ok, thanks KromeX We shall see what they can do for me..:smile:
Old 04-17-2002, 07:42 PM   #10
H.A.N.S
My Ride: Hamann 330ci
Thats exactly whan happened to mine (after motor swapping). The motors are all up-side down. Basically all in wrong directions. Anyway to solve this problem???
H.A.N.S is offline   Reply With Quote
Old 04-17-2002, 07:45 PM   #11
NickACS
BOOM!
Yea, not sure...I don't care if up=down and down=up with the switches, just as long as the mirror goes back to my memory presets! hehehe Thats what I can't stand! :sad:
Old 04-26-2002, 02:17 AM   #12
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Those in your Sig--they're Hagus, no? Or did you go and get the ACS ones?
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 04-26-2002, 06:59 AM   #13
NickACS
BOOM!
Those are the Hagus and yes, I still have them. Still debating on going for the ACS ones if my bodyshop can't retrofit my OEM motors into the Hagus mirrors!
