Old 04-17-2002, 02:46 PM   #1
Derek330xi
My Ride: E46 330xi
Send a message via ICQ to Derek330xi
anyone have DIY file for oil change on sedan?
do u guys jack your car up and use a stand or just drive the car on a ramp?
Derek330xi is offline   Reply With Quote
Old 04-17-2002, 02:50 PM   #2
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
You don't need to jack the car up that much... it's real easy to change the oil. Lift one side of the car up a couple inches and just reach up and undo the drainage plug afer removing the cover... it's simple. If I can do it... ANYONE can :tongue:
B is offline   Reply With Quote
Old 04-17-2002, 02:51 PM   #3
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
I use the hydraulic lift in my friends shop
Up she goes. High in the air.
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
Old 04-17-2002, 03:09 PM   #4
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
Ramps work just fine...
I just did my oil change a few weeks ago...very easy.
vinnymac is offline   Reply With Quote
Old 04-17-2002, 03:19 PM   #5
BMW328i2000
[name here]
BMW328i2000's Avatar
My Ride: 2000 BMW 328i
what about changing the oil fliter?
BMW328i2000 is offline   Reply With Quote
Old 04-17-2002, 03:34 PM   #6
Mr.Stream
That is the easy part. If you see the black cover in front of the engine and strutbar (A little to the right in the pic.). Behind the black tube and to the left of the generator and the airfilter. This is where the filter is located. Just unscrew it and pull up. Remember to change the O-rings.
And dont mind the small enging
Stig Johansson
Norway
Old 04-17-2002, 03:39 PM   #7
Mr.Stream
Here is another shot.
The round black lid. In the left of the pic.
Stig Johansson
Norway
Old 04-17-2002, 03:51 PM   #8
joe330ci
My Ride: 330ci
which side of the car do you jack up? drivers or passengers?
joe330ci is offline   Reply With Quote
Old 04-17-2002, 03:54 PM   #9
finnegan
Here's the DIY link I used:
http://www.bmw330ci.com/DIY_Oil_Change.htm
finnegan is offline   Reply With Quote
Old 04-17-2002, 06:21 PM   #10
KromeX
all stock
My Ride: stock 330i
Before anyone gets seriously hurt or even worse when crawling under your car, I'd strongly suggest you guys make sure your car is supported by jackstands especially if you are only using the jack that's been included inside the trunk.
KromeX is offline   Reply With Quote
Old 04-17-2002, 06:42 PM   #11
Derek330xi
My Ride: E46 330xi
is the axle stand ok??? how about if i just drive the car on the ramp???
Old 04-17-2002, 06:45 PM   #12
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Go with the ramps.
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
