Old 11-20-2003, 03:03 AM   #1
ed102030
My Ride: 323ci
Send a message via AIM to ed102030
What's the significance of 37 degrees
It's getting colder here in the DC area and when the temp outside reaches 37 degrees my car beeps.
What's the significance?
ed102030 is offline   Reply With Quote
Old 11-20-2003, 03:05 AM   #2
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
its a warning to you that you might encounter slippery roads due to ice/black ice situations.
Mr.Motorwerk
MrMotorwerk is offline   Reply With Quote
Old 11-20-2003, 03:18 AM   #3
TeKNiC330
Banned
My Ride: IS ON STOCK 17'S
Yup, just an ice warning
TeKNiC330 is offline   Reply With Quote
Old 11-20-2003, 03:22 AM   #4
woobiee
My Ride: JetBlack E46 323Ci
Send a message via AIM to woobiee Send a message via Yahoo to woobiee
i was kinda wondering the same. shouldnt it be 32 since water freezes at 32, not 37. am i wrong on this?
woobiee is offline   Reply With Quote
Old 11-20-2003, 03:31 AM   #5
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
bmw knows its temprature guage isnt that accurate so it beeps at 37 casue it maybe 32 out there on the ground
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
Old 11-20-2003, 03:49 AM   #6
bmwfan328
My Ride: M3 Vert
also, even if the temp really is 37 degrees outside, it may actually be colder on certain areas such as bridges, which tend to freeze over quicker than regular roads. nonetheless, it's nice to have a warning before roads actually do freeze.
bmwfan328 is offline   Reply With Quote
Old 11-20-2003, 04:08 AM   #7
woobiee
cool deal.
Old 11-20-2003, 09:48 AM   #8
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
that is a warning to the driver
that their may be black ice on the road. usually when the weather goies below freezing that message will come on when you start your car. giving you the temp. outside. usually it it at the freezing temp. mark and below.
bobm3
bobm3 is offline   Reply With Quote
Old 11-20-2003, 09:53 AM   #9
CYBER PETE
Dinan Pimp
My Ride: 2006 Honda Ridgeline
Generally speaking the ground is warmer than the air (for example snow doesn't always stick when it snows because the ground is warmer than the air.) Also in my experience the temperature gauge is VERY acurate. 99% of the time it's within 1 degree of the temperature as reported on the radio or the thermometer on my porch.
The beeping is actually extremely annoying. I live in Buffalo I know it's cold! Evertime I turn my car on for 4 months out of the year the dam car beeps at me. I'm still not use to it..when I hear my car beeping at me I'm looking to see what the hell is wrong with it. Can this feature be turned off?
CYBER PETE is offline   Reply With Quote
Old 11-20-2003, 09:57 AM   #10
SHICKS
My Ride: 325i
Send a message via AIM to SHICKS Send a message via Yahoo to SHICKS
I know the anwser to this question, but I'll ask anyway. Does it beep if you don't have the OBC?
SHICKS is offline   Reply With Quote
Old 11-20-2003, 10:14 AM   #11
tanium325
My Ride: 2005 330i SMG
Actually It beeps at 37 because that is the temprature that ice can form on overpassses and bridges. I thas nothing to due with accuracy of the thermometer, in fact it is very accurate to within 1 degree 1+- while moving.
tanium325 is offline   Reply With Quote
Old 11-20-2003, 11:05 AM   #12
bookus11
is baaaaaaaaaack...
My Ride: 2006 M3 SMG
Send a message via AIM to bookus11
its just for bridges, its true that the ground is warmer than the air, except with bridges because they have the air moving underneath them. hence, the warning.
***thanks to jlevi for making my sig***
02 330xi 5-Speed... retired
06 M3 SMG... mine
07 X5 3.0i... hers
bookus11 is offline   Reply With Quote
Old 11-20-2003, 01:57 PM   #13
Dukes
My Ride: '00 540i 6sp
Send a message via AIM to Dukes Send a message via Yahoo to Dukes
It's in the manual too I believe.
Also you wouldn't want your car to warn you when it is 32 degrees F would you? That's way too late.
Dukes is offline   Reply With Quote
Old 11-20-2003, 02:08 PM   #14
RichP
Big in Japan
My Ride: Mid-engined Madness
You guys need a science refresher course! 37 is significant because it is cold enough where evaporative cooling of wet surfaces (especially bridges where there is no warmth from ground below) is enough to bring the surface water to 32 degrees and thus ice formation. In this scenario you only see black ice, which as anyone knows, is the most dangerous because road simply appears wet.
RichP is offline   Reply With Quote
