Sponsored by The Tire Rack
Old 04-17-2002, 07:53 PM   #1
Derek330xi
My Ride: E46 330xi
Send a message via ICQ to Derek330xi
tire pressure for 18" tires
what psi do u guys run on your 18" 235/40/18? i have no idea why but i couldn't find the recommended psi on the tire.
Derek330xi is offline   Reply With Quote
Old 04-17-2002, 07:55 PM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
I ran between 33 and 35 all around
Clem is offline   Reply With Quote
Old 04-17-2002, 07:56 PM   #3
Derek330xi
My Ride: E46 330xi
but aren't the rear tires suppose to have more psi? for the 17" the sticker with the psi for 17" on my car always had the rear 3 psi more than the front.
Old 04-17-2002, 08:18 PM   #4
Clem
Alpha Male
Clem's Avatar
That setup I believe creates more understeer. That's why BMW set it up that way.
Old 04-17-2002, 08:44 PM   #5
Derek330xi
My Ride: E46 330xi
is that a good thing or bad thing? so u mean is better to have same psi all around? thanks
Old 04-17-2002, 09:11 PM   #6
JJK-E46
My Ride: '01 X5 3.0
I have 225/40/18 all around and
Use 35/front and 37/rear.
E46 328i SOLD
JJK-E46 is offline   Reply With Quote
Old 04-18-2002, 12:34 AM   #7
InlineSiX
illstylez
My Ride: 1999 328i
i have 225/40/18's and have been running 40 psi all around...probably too high then?????
InlineSiX is offline   Reply With Quote
Old 04-18-2002, 01:17 AM   #8
JJK-E46
My Ride: '01 X5 3.0
I did a search on the old forum archives and found that most people running the same as miine. In addition, look onthe side of your driver side door. It'll tell you what the manufacture recommends...
I think it is a bit high, especially b/c the weather is warmer now too.
E46 328i SOLD
Old 04-18-2002, 01:52 AM   #9
InlineSiX
illstylez
My Ride: 1999 328i
that's what's so great about this forum...quick feedback! Thanks!
Old 04-18-2002, 04:08 AM   #10
JJK-E46
My Ride: '01 X5 3.0
No problem dude. But you won't always get a quick response.
I'd recommend checking older archives 1st. There is alot of good info that has already been discussed.
E46 328i SOLD
