Old 12-11-2003, 12:59 AM   #1
mindwarper
My Ride: 2002 E46 M3
Send a message via AIM to mindwarper
Do they make a Wax for wheels?
All of us have problems with keeping our wheels clean. Ive heard of a couple ppl saying they make a wax for the wheels which not only gives it a better shine but keeps the brake dust from getting on there so fast. Is this true or just a lot of BS?
mindwarper is offline   Reply With Quote
Old 12-11-2003, 02:54 AM   #2
doughsun
aka Ko Chun
My Ride: is retired...
I use Mother's Billet Polish and then I use Zaino
doughsun is offline   Reply With Quote
Old 12-12-2003, 07:31 AM   #3
scud
My Ride: 328ci, R1, YZF, XV
Mothers....
Mothers is the best **** on the planet- although it does take a LONG LONG time to do it if you're gonna do it right. I polished my aluminum wheels beyond factory- went up to 2000 wet sand and then used hand glaze followed by religious mothoers applications in the summer- mothers usually takes 2 full doings to get each wheel right, which is at least 1/2 hour per wheel- usually more.
If your wheels are polished aluminum and you want to really make em shine, you can try the wet sanding thing- restores, beautifies- you just have to stay on top of them in terms of protection from the elements
scud is offline   Reply With Quote
Old 12-12-2003, 08:07 PM   #4
FredS
Banned
My Ride: 2001 BMW 330ci
Send a message via AIM to FredS Send a message via MSN to FredS
How do you wet sand? If you could tell me exact details and products, thanks
FredS is offline   Reply With Quote
Old 12-12-2003, 09:18 PM   #5
silver323i
My Ride: 1999 323i
Send a message via AIM to silver323i
Griots also has wheel wax, and I'm not sure but you may be able to use regular wax as well.
silver323i is offline   Reply With Quote
Old 12-14-2003, 04:06 PM   #6
Chocaine
My Ride: '04 330ci
I use regular wax and it works fine, does anyone think a wheel wax provides better protection than a normal carnauba?
Chocaine is offline   Reply With Quote
Old 12-14-2003, 05:09 PM   #7
scud
gotta see for yourself... and wet sanding
Sometimes the combination of marketing and mind-over-matter can be a very good way to generate cash!
If you ask people who supposedly know, they'll say the wheel wax allegedly does a better job at repelling things after it's applied and buffed- namely brakedust. I usually use mothers to really polish the **** out of the wheels and get them clean. After, I use a coat of turtle wax or gliptone- either one, and they seem to keep the wheels looking hot for a good couple of weeks... I mean it depends, but assuming it's spring or summer or eaRly fall, and there's not too much crap on the road, they'll stay nice. Is the wheel wax worth the money? you know, as skeptical as i am, it may just be! I used it on another of my old cars at a friends house, and I couldn't believe how good it looked for so long.. but you should try both and see...
Wet Sanding: You wet sand with special paper designed to sand with a thin coat of water- you basically get a bucket of water, a good sanding block- you'll want a firm-sponge for wheels, so it will adhere to the curves and get good surface contact.
wet sanding paper is black- not brown or beige. It's kind of like emory clotch, but it's actually paper, not cloth. still it resists water and lets the water lubricate so it doesn't have such an abrasive effect, but more of a polishing effect. You should start with 400 (320 if they're really messed up) and work all the way through 600, 1000, 1400 and 2000 grit if you want to go nuts. Then a good polish with mothers or hand glaze (3m) finished with a good coat of wax... it's a labor of love, but well worth it~!!!
Old 12-27-2003, 02:48 AM   #8
greeps
My Ride: '04 330Cic 6spd
I got the "Wheel Wax". I took off each wheel, cleaned it and used the wheel wax on both the outside (visible) and inside (back side) of each wheel.
The things seem to get just as dusty just as quickly as before. They're fairly easy to clean now. I think any regular wax would do just as well.
They claim "WheelWax changes the surface polarity of your wheels to repel brake dust particles" on the Wheel Wax website.
I had hopes the wheels would stay cleaner. I now think this claim is probably misleading.
If, indeed, the polarity is changed, perhaps it doesn't matter if the surface polarity is changed. I'd assumed by "changes" they meant "reverses" but I now suppose any alteration of charge would fit the definition of "changes".
Still, my wheels certainly don't "repel brake dust particles" so I assume their claim is based more on marketing strategies than on science.
Visor airbag warnings removed, XM Radio, UUC short shifter,
black/white roundels, black calipers, black kidney surrounds.
greeps is offline   Reply With Quote
