Old 06-21-2002, 01:41 PM   #1
Vics
Canadian e46Fanatic
My Ride: 2001 330ci
UUC spings, allignment required?
Is an allignment required when installing the UUC tuned spring set on a 330ci? The site says stock alingment specs can be respected, when I put them on will the allingment not be stock?
Vics is offline   Reply With Quote
Old 06-21-2002, 02:22 PM   #2
James330I
Imported Redneck
My Ride: BMW baby 330i 5spd
Send a message via AIM to James330I
yes, you have to.
The shop should then adjust suspension as close as possible to OEM settings.
Bummer eh. Alignment is kinda pricey where I live.
2001 Dinan 330I 5spd.
2011 Infiniti M37S
James330I is offline   Reply With Quote
Old 06-21-2002, 02:23 PM   #3
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Yes, it's good to go ahead and get an alignment done (better safe than sorry).
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 06-21-2002, 02:36 PM   #4
newbieguy
My Ride: '09 E93 M3 S. Gray
Everytime you replace shocks or springs in any car, you need to get an alignment. You dont want your tires to wear out prematurely or have the car pull to either left or right while your driving.
'03 JB M3
'01 330ci gone but not forgotten
newbieguy is offline   Reply With Quote
Old 06-22-2002, 03:52 AM   #5
Jspeed
My Ride: '01 330i
BTW it's going to be the toe setting and and rear camber that you should look at. The slight extra negative camber up front from lowering is desirable, and the caster would not change from lowering.
Jspeed is offline   Reply With Quote
