Old 06-21-2002, 04:28 PM   #1
BAVARIAN323i
Ballin'
My Ride: 1999 323i
Send a message via AIM to BAVARIAN323i
Question about the intake...
I video taped the engine while reving it with the stock and ecis intake.
When the stock intake was in, two little doors simutaneously opened with the reving, on either side of the grill. With the ecis they did not open.
does anyone know why?
SOLD
1999 e46
-Jim Confronti Shark Injector Software
-18x8.5 Breyton Inspirations
-Bridgestone S-03 Potenza Pole Position’s
-H&R CupKit w/ M3 RSM & Z3 plate
-UUC Pedals
-European Lights w/ Silvervision Bulbs all around
-DEI Shock Sensor
BAVARIAN323i is offline   Reply With Quote
Old 06-21-2002, 04:30 PM   #2
drewcon
Bavarian Motor Slave
My Ride: 330ci
little doors?
no clue...so why did i even respond you ask, I'm not sure.:tongue:
drewcon is offline   Reply With Quote
Old 06-22-2002, 03:49 AM   #3
Jspeed
My Ride: '01 330i
I think I know what you're talking about. Those flaps open up when the throttle opens beyond a certain point. When you video taped the ECIS, was the hood open? If so, the heat-shielded area would not be enclosed and the vacuum wouldn't be great enough to open up any of those flaps.
Jspeed is offline   Reply With Quote
Old 06-22-2002, 08:54 AM   #4
KevinJ_2k1_325ci
My Ride: 2001 325ci
Exactly
Remember that the ECIS doesn't rely alone on the intake grill. It also is getting a fair amount of air from the front headlight below the bumper. If a great enough vaccum is created those little flaps will open but are negligable with the ECIS since it's getting more air from other areas.
KevinJ_2k1_325ci is offline   Reply With Quote
Old 06-22-2002, 10:45 AM   #5
BAVARIAN323i
Ballin'
My Ride: 1999 323i
ok, the only thing is that I videoed it with the hood open for both the stock and ECIS. The doors opened for the stock, and not the ecis
SOLD
1999 e46
-UUC Pedals
-DEI Shock Sensor
Old 06-22-2002, 02:01 PM   #6
Jspeed
My Ride: '01 330i
Yes, but the stock airbox is self-enclosed, where the ECIS relies the hood to be closed to complete the enclosure.
Old 06-22-2002, 02:08 PM   #7
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
yup!
B is offline   Reply With Quote
Old 06-22-2002, 03:58 PM   #8
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
what if you got rid of these little doors? would you see an increase in power, even with throtle aplications that before would not have created the vacuum to open the doors?
-brendan
Old 06-23-2002, 12:26 AM   #9
KevinJ_2k1_325ci
My Ride: 2001 325ci
Here's the deal
Since at low end RPM, the throttle is almost completely closed under 2500 RPM, there's very little need for air intake. Once speed builds above 25mph the doors will probably open letting more air in thus letting more air into the throttle. The RPM from 0-2500 relies purely on a small amount of air and more gas mixture for combustion which the ECU takes care of automatically. This is why you need your ECU tuned with a cold air intake if you want to take advantage of it at low end speed, otherwise all the benefit is mostly at the high end RPM.
Bottom line, you will get no benefit from opening the little doors. Get a cold air intake instead with a tuned ECU.
