Old 06-22-2002, 01:19 AM   #1
core
[]D[][]V[][]D[][]\[]
core's Avatar
My Ride: 2003.5 E46 ///M3
5 spd - Driving without using...
the clutch ?!?!?!?! a friend of mine knows how to do this.. anyone here know how it works ? is it good / bad for the car ? pls share any info!
2003.5 E46 ///M3 6 speed
core is offline   Reply With Quote
Old 06-22-2002, 01:35 AM   #2
UltimateOne
Fanatics vs. E46 DTM 4evar
My Ride: Mustang GT
Send a message via AIM to UltimateOne
I did it one night in a WRX but its definitely not good to do.
UltimateOne is offline   Reply With Quote
Old 06-22-2002, 01:38 AM   #3
lilherc79
"DPErt-ASchnizA-*****"
My Ride: ASA ACS 3.0 Cabrio
how the heck do u do that? jam it in???? lol
lilherc79 is offline   Reply With Quote
Old 06-22-2002, 01:40 AM   #4
UltimateOne
My Ride: Mustang GT
You have to match the rpms...its pretty kookoo
Old 06-22-2002, 01:42 AM   #5
core
core's Avatar
i would definetly do it on a loaner lol
Old 06-22-2002, 02:01 AM   #6
Amil
mY Name Is aMiLioooooooO
Amil's Avatar
My Ride: 04 Range Rover 07 A4
Send a message via AIM to Amil Send a message via MSN to Amil Send a message via Yahoo to Amil
yeah i do it all the time ...im getting better @ it, try takin it out of gear without the clutch thats the easiest
ooolala
Amil is offline   Reply With Quote
Old 06-22-2002, 02:03 AM   #7
lilherc79
so how exactly do you do this/"???? sounds dangerous. liek grindin ur gears. anyone want to provide a detailed instruction?
Old 06-22-2002, 02:23 AM   #8
Full Time Hit Man
Banned
My Ride: E46
Send a message via AIM to Full Time Hit Man
You have to know the car pretty well. YOu have to match the rpm when you move into gears. This is what people do when they are driving trucks. The good thing about it is you are easy on the clutch, so no need to change the clutch that often. But you have to use the clutch when you start the car from a stop.
Full Time Hit Man is offline   Reply With Quote
Old 06-22-2002, 02:29 AM   #9
shouldibuy
My Ride: thinkina4vs325i
what?
how do u match rpm?
can u illustrate w/ example perhaps?
shouldibuy is offline   Reply With Quote
Old 06-22-2002, 03:00 AM   #10
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
Most people wear out their clutches in first gear though, so how does this help your clutch last longer?
SrCsTc is offline   Reply With Quote
Old 06-22-2002, 03:01 AM   #11
sycE46
My Ride: 323ci
At a certain RPM you can pull your shifter out of gear without using your clutch. I did it by accident a couple of times. I've never tried to put it back into gear without the clutch.
sycE46 is offline   Reply With Quote
Old 06-22-2002, 03:41 AM   #12
neopunk1
My Ride: 330ci
Send a message via AIM to neopunk1
I do this sometimes with my old Honda. Can only get it to work in 3rd to 5th gears. Yep, rpms matching and u have to know your car very well. Somehow I feel that I abuse my car doing this
2k1 TiAg Hamann 330ci:pimpin:
2k 4Runner SR5 4WD:dunno:
'83 Accord Hatchback (287K miles and going, a keeper):thumbup:
neopunk1 is offline   Reply With Quote
Old 06-22-2002, 05:23 AM   #13
bender
hammer talks like this
My Ride: 2006 Honda insight
Send a message via AIM to bender
my friend has a 85 jetta that he can do this on... its freakin funny.... hahaha
bender is offline   Reply With Quote
Old 06-22-2002, 07:02 AM   #14
Dan Wu
I've NEVER executed one successfully, but here's the theory behind it...
1) Slipping car out of gear: When your engine load is equal to your tire load, i.e. coasting with your foot off the brake and gas, and when the engine isn't doing too much engine breaking, it's easy to slip your gear back into neutral
2) Rev match: This takes a lot of getting used to. If you're going up 1 gear, then your RPM has to drop accordingly, like if you're going from 3rd to 4th @4,000 rpm, then your engine has to be spinning at ~3,000 rpm or so in order for the gears to line up.
3) Once your rpm matches your wheel speed, it should be possible to slip your shifter into the next gear w/o any resistence or grinding.
In modern day BMWs upshifting w/o using the clutch is damn near impossible since the RPM HANGS regardless of what engine software you're running with for emission purposes, so it would take forever to match RPM before you can shift into the next gear. Down shifting is possible but which is cheaper, your clutch, or a new transmission?
Dan Wu is offline   Reply With Quote
Old 06-22-2002, 07:28 AM   #15
Munich
Happy
My Ride: Volvo S40 2005
Do it if you want a shorter life for your transmission, besides it's a PITA to be matching RPM's.
Munich is offline   Reply With Quote
Old 06-22-2002, 08:23 AM   #16
Scoot
My Ride: 2001 325i (blk/blk)
Yes, it's possible, but I don't recommend it unless you want to replace your synchros. Use the clutch!
Scoot is offline   Reply With Quote
Old 06-22-2002, 10:23 AM   #17
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
I worked at Avis carrental. We "used" those cars really good. I shifted gears without using the cluch. From 2. to 3. and 3 to 4. is the easiest. Its just to let go of the gaspedal and slip it garefully into gear. When its done right, it should feel like you are using the cluch. BUT I DONT RECOMEND IT!!!!!!
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
Old 06-22-2002, 10:28 AM   #18
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
don't know if this is related..
.. when u downshift.. (with clutch) how much more rpm do u add?\
is there like a forgiveable range?... I was told it's 700rpm more..between each gears.. (and it works fine, still need more practice tho.. screw up all the time..)
and as above mentioned.. it's 1000rpm..
damn. I wish I have my car to find out..
can someone try for me??
thanx in advance..
Orz
BMWintoxication is offline   Reply With Quote
Old 06-22-2002, 10:43 AM   #19
Runurass
RunUrAss
My Ride: 2002 325ci
Send a message via AIM to Runurass
it's called "Power shifting" :tongue:
Runurass is offline   Reply With Quote
Old 06-22-2002, 11:10 AM   #20
deputydog95
My Ride: Looking for a 330...
actually powershifting
is then you shift using the clutch....but you never let up on the gas. WOT the whole time. talk about hard on the clutch and tranny. keeps those rpms up though.
deputydog95 is offline   Reply With Quote
