Old 03-21-2004, 12:45 PM   #241
Spiral Prophet
Über-Geek
Spiral  Prophet's Avatar
My Ride: '01 Topaz Blue 330ci
Send a message via AIM to Spiral  Prophet
Originally Posted by russ330
Here ya go bud, hopefully this will help.
First pull up the trim
second get the plug outta the way
thrid pull on that pin
-the pin does not need to come all the way out (I don't think it can anyway))
I broke that pin accidently.. anyone have a part # for it.. so i can replace it?... other than that.. the install went extreemly easily..
pictures comming soon..
~T|/\/\
Spiral  Prophet is offline   Reply With Quote
Old 03-21-2004, 12:49 PM   #242
FazTaz
My Ride: 04 330Ci
Hey guys where does the washer go? On the bolt side, nut side, on the inside or outside?
2004 330Ci 6-Speed
Titanium Silver/Black
PP, SP, CWP, Xenon,
UUC Sways, EVO3, TSE3, 3.46 Diff, BFP Front Strut, 18" CSLs
FazTaz is offline   Reply With Quote
Old 03-21-2004, 12:58 PM   #243
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
~T|/\/\
Russ is right that pin doesnt come all the way out, the part # for that bolt is
61 13 8 377 630
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 03-21-2004, 01:31 PM   #244
bimmerman11
My Ride: 2005 330Xi
Send a message via AIM to bimmerman11
I just dremeled the pin out= the battery box is lifted up.
Now I'm having trouble fitting the endplates on. One of the 3 holes doesn't go all the way down. How did you guys do it? Did you line up all three holes first and then press down? Or did you do it one hole at a time?
Thanks.
Marc
bimmerman11 is offline   Reply With Quote
Old 03-21-2004, 01:33 PM   #245
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
^^ I ended up lining them all up at the same time. I had to push like a mofo to get them things on, but they're on. They definitely did not slide right on, I had to use a good amount of elbow grease.
russ330 is offline   Reply With Quote
Old 03-21-2004, 01:36 PM   #246
bimmerman11
My Ride: 2005 330Xi
Hopefully that'll do the trick. Thanks for the help Russ.
Marc
Old 03-21-2004, 02:26 PM   #247
BFP, Inc.
Past Site Sponsor
My Ride: S/C E39 540i
Marc
Hey guys, I dunno why 2 ppl have had difficulty with the bases. On our test vehices they slid right on. Maybe we need to drill the holes slightly bigger? In any event, please let us know if you're experiencing difficulty installing.
Regards,
-Dan
BFP, Inc. is offline   Reply With Quote
Old 03-21-2004, 03:15 PM   #248
russ330
Mod Squad
russ330's Avatar
^^ I think doing that would help a lot. If the holes were only a touch bigger, it would have made life a lot easier, on the flip side, I do like the fact that the bases make a really tight fit once they're in.
Old 03-21-2004, 04:20 PM   #249
BFP, Inc.
Past Site Sponsor
So for the people who have installed their bars, WHERE ARE THE PICS!?!? (Ok, RichP came through)
I'd like to see some because
Old 03-21-2004, 04:36 PM   #250
russ330
Mod Squad
russ330's Avatar
^^ Got some pics for ya over here Dan. http://forum.e46fanatics.com/showthr...37#post1436437
Old 03-21-2004, 04:39 PM   #251
BFP, Inc.
Past Site Sponsor
Oh man, that's lookin' sweet! I like this pic...
Old 03-21-2004, 06:43 PM   #252
russ330
Mod Squad
russ330's Avatar
^I figured you would.
Old 03-22-2004, 09:56 AM   #253
Spiral Prophet
Über-Geek
61 13 8 377 630
Thanks...
Oh and Dan.. i have pictures.. just gotta find time to resize them and post em... cause i don't think 25 meg pictures are very net friendly..
~T|/\/\
Old 03-22-2004, 06:08 PM   #254
Obsidian
My Ride: M3 Vert
I had trouble putting on the passenger side brace. Actually had to use a small hammer and flat head screw driver to "knock" them into alignment. I broke off one of the mounting posts, the inner one, which sucked. I ordered a new one from circle bmw for 25.00 and will put it on whenever my suspension needs changing. Right now it doesn't seem to effect steering/suspension at all. Oh well.
Obsidian is offline   Reply With Quote
Old 03-22-2004, 06:55 PM   #255
gil323
My Ride: '99 323i
Send a message via AIM to gil323 Send a message via Yahoo to gil323
Regards,
-Dan
I actually had to bore out the holes to make them a bit bigger. Needed to do this to 2 holes on each end as the base would not slide on at all. Not even w/ a bit of elbow grease
Each of the holes was off by a couple of mm or so. My car has been around the block many many times so, it's probably just a shifting/time issue.
Will try to post some pics tomorrow. Otherwise, a great looking product.
gil323 is offline   Reply With Quote
Old 03-22-2004, 07:42 PM   #256
BFP, Inc.
Past Site Sponsor
Interesting. Seems like some people are having this fitment issue. I will have the manufacturer drill the holes larger and double check the hole locations for future bars. In the meantime, if anyone wants their bases drilled out, PM or email me and we will have this done ASAP.
Regards,
-Dan
Old 03-22-2004, 07:59 PM   #257
Gretz99
My Ride: '04 M3 LSB on LSB
Any update on the M3 bars??
Gretz
Gretz99 is offline   Reply With Quote
Old 03-22-2004, 09:07 PM   #258
BFP, Inc.
Past Site Sponsor
Gretz
I'll visit the manufacturer tomorrow and report back.
-Dan
Old 03-23-2004, 12:35 PM   #259
King Jason
My Ride: 04 330Ci ZHP
Send a message via AIM to King Jason
Any idea if there will be another gruop buy?
-The King has spoken
'04 Imola Red 330Ci ZHP
King Jason is offline   Reply With Quote
Old 03-23-2004, 02:32 PM   #260
JCsE46
(oOO \ (||||)(||||) / OOo)
JCsE46's Avatar
My Ride: 03 E46 JB, 08 MBE350
Send a message via AIM to JCsE46 Send a message via MSN to JCsE46
Yeah!! Will there be another one??
I've missed the first one. I will be interested to sign in with the group.
JCsE46 is offline   Reply With Quote
