Old 12-17-2003, 09:30 AM   #1
Artan5
life is a *****..........
Artan5's Avatar
My Ride: 330ci :) RIP323i
Send a message via AIM to Artan5
Jump starting a bmw
ok how the hell do you jump start a bmw? my battierry died and it like charged itself and i havent had any problems, but how do you jump start your car if the batterie is in the trunk
Artan5 is offline   Reply With Quote
Old 12-17-2003, 09:39 AM   #2
325seeeye
Core Fanatic
My Ride: 325Ci, e36 325is
There are terminal posts under the hood, use them. The manual also has the information.
325seeeye is offline   Reply With Quote
Old 12-17-2003, 09:41 AM   #3
Artan5
Artan5's Avatar
i see the positive one but cant find the negative
Old 12-17-2003, 09:42 AM   #4
MIAMITOPAZ
My Ride: Rieger323CI
Send a message via Yahoo to MIAMITOPAZ
in your engine there's a little black box ( postive battery terminal) open it. and behind it there is a ground terminal that goes to the chassis. clip the jumper cables there.
MIAMITOPAZ is offline   Reply With Quote
Old 12-17-2003, 09:43 AM   #5
Alan L.
TWC Alumni
Alan L.'s Avatar
My Ride: AW M-Sport
On my car.....the negative post is sorta behind the postive inside the area where your DSC pump is located.
Alan L. is offline   Reply With Quote
Old 12-17-2003, 09:47 AM   #6
325seeeye
Core Fanatic
Old 12-17-2003, 09:48 AM   #7
Artan5
Artan5's Avatar
i checked mine and i found the negative. i have a 99 and i dont have dsc, so maybe thats why its diffrent
Old 12-17-2003, 09:58 AM   #8
freccetta
My Ride: Alfa 159/GSX-R 750
Send a message via MSN to freccetta
even the big bolt that holds your coil/spings is a good negative
freccetta is offline   Reply With Quote
Old 12-17-2003, 10:50 AM   #9
M3Inline6
Chillin'.....Killin'
My Ride: M3/848/128i
Is your car a manual? If so, you may just be able to "push start" the car.
Sou Instrutor de Capoeira ate' morrer.
Originally Posted by unionjack View Post
Dude, you are massively gay for Capoeira. Yes I know this has been well established for quite some time.
While not big, I bet it's firm and can grind the sh1t out of a crank.
M3Inline6 is offline   Reply With Quote
Old 12-17-2003, 11:02 AM   #10
ADA
Banned
My Ride: 323ci
damn! I am such a retard!
I jumped my car three times. All three times, I connect the jumper cable directly to my battery in the trunk!
I am such a retard!
ADA is offline   Reply With Quote
Old 12-17-2003, 11:25 AM   #11
grizzy727
My Ride: 08 m5 + 04 911=845hp
u dont use a negative post on the car that gets jumped--you use a ground
grizzy727 is offline   Reply With Quote
Old 12-17-2003, 11:31 AM   #12
ininfinitum
Super Nintendo Chalmers
My Ride: 330
M3Inline6, did you get the CHP job??
ininfinitum is offline   Reply With Quote
Old 12-17-2003, 11:35 AM   #13
blkonblk
My Ride: 06/2000 330i ZSP/ZPP
I am such a retard!
Life is a journey not a destination, so enjoy the ride!
blkonblk is offline   Reply With Quote
Old 12-17-2003, 11:40 AM   #14
GeoMystic
My Ride: '03 330i ZHP
You should always use the car chasis as ground, not the negative terminal.
2003 330i Mystic Blue - Black Alcantara/Cloth
6 Sp Manual | Performance Package | Cold Weather Package | Silver Cube Trim | Navigation | Bi-Xenons | Moonroof | PDC
OEM Clears - OEM Alarm - OEM TV Function retro - Blaupunkt DVD-ME3 - HD-DICE - DIY Clutch Stop - Silver headlight inserts - M3 Rearview Mirror - OEM ///M Dead Pedal - Euro First Aid Kit - Euro Warning Triangle - 35/20 Window Tint - ECIS CAI - ACS Style Roof Spoiler
GeoMystic is offline   Reply With Quote
Old 12-17-2003, 11:43 AM   #15
Commander FAT
Network Analyst
My Ride: 2002 330Ci
The negative terminal is attached to the frame anyway. So it doesn't matter if you connect to the actual negative terminal or the chasis of the car.
dave
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 12-17-2003, 11:46 AM   #16
T_DOT_BIMMER
My Ride: 2003 BMW 330i
just connect the positive (under the hood) to the positive on the other car, then the negitive to the other car...then ground the other negitive to ur car...i think thats how it goes?
T_DOT_BIMMER is offline   Reply With Quote
Old 12-17-2003, 11:49 AM   #17
M3Inline6
That process is still frozen due to the state budget. Once that's taken care of, then they'll open the Academy and I'll be all good.
Update however....
Tested for Covina P.D. Got as far as the oral exam, but I didn't pass it. There were a pretty large number of individuals that made it to the oral process in that situation, but there were only 3 positions. It's a difficult process to overcome. I also applied to Upland & Ontario P.D. I work for the Govt., so I may try to lateral into the Sheriff's dept. (see pic ). I have my test 2/3/04!
I also have another outlet. My g/f's boss has a cousin that does the background for LAPD. He said he could get me through that after I take the written/physical. He could use his "pull" to get me through the oral. I'd be doing either L.A./Ontario Airport Customs work. I really don't want to commute, but that's the price I'll have to pay if I want the job.......unless, I get Ontario as my initial assignment.
Old 12-18-2003, 12:54 PM   #18
E28Fiend
Track it
My Ride: '06 M3
Send a message via AIM to E28Fiend
whaaat...you tryin to be the man?
E28Fiend is offline   Reply With Quote
Old 12-18-2003, 12:56 PM   #19
ininfinitum
My Ride: 330
Wow, seems like you have the job opportunities goin' for ya. Hopefully we'll get out of this deficit soon!
Update however....
Old 12-18-2003, 02:02 PM   #20
GeoMystic
dave
WRONG, it does matter. Batteries produce highly explosive hydrogen as a byproduct of the charging process. Batteries often explode when the owner is trying to jump start his or her car. The spark from the contact of the last jumper lead can ignite the hydrogen causing an explosion spreading battery acid everywhere.
The way to avoid this is to connect the positive and negative leads to the battery of the donor car, and at the dead battery, connect the positive lead to the battery and then find a place far removed as possible on the frame of the car for the negative lead. This will still spark but it should be far enough away not to ignite any hydrogen coming from the battery.
This is a VERY important and very simple technique to follow when jumping your car. It can save you headache and injury.
