Old 12-23-2003, 11:41 PM   #1
tifosi
My Ride: M5
Send a message via ICQ to tifosi Send a message via MSN to tifosi
pressure jet washer
thinking about getting a pressure jet washer along with an electric blower just so my car can stay swirl free
however, friend of mine told me that the high pressure water blasting on the dust of body panel can cause swirl mark anyway.
so is using a pressure jet washer will really help me keep swirl mark to minimum on my car? any thoughts? Thanks
tifosi is offline   Reply With Quote
Old 12-24-2003, 09:24 PM   #2
04ragtop
My Ride: 04 330 Cic
Not good for your paint. Too much pressure. Won't get all the dirt off. Will likely push water past your window seals and into the car.
The only way to get your car truly clean and prevent damage is to hand wash. If you rinse it really well and use a very soapy sponge with a gentle touch, you shouldn't be leaving swirl marks.
You might be getting swirl marks because you are not getting your car completely clean and then you are drying it and accidentally rubbing the slight dirt residue into your paint.
04ragtop is offline   Reply With Quote
